![]() | Home > Maintenance & Mods (L322) > Change Key Fob Buttons? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I really need to change the buttons on my key fob.
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 ![]() ![]() |
http://www.polmex.com.au/pdf/Rover%20L322%...cedure.pdf |
Thanks for the howto HGVDriver .
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
I have just done this. It looked to me that the rubber would be very easy to damage and so I pulled the new key blade out of the plastic fob by pulling it side to side with a pair of pliers. There are no lugs on the blade. Did the same to the new key but this time I wrapped the key in some thick cloth so that it did not damage it then glued the key into the new fob with superglue. Tried it and all seems OK. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
I tried the replace fobs but had no success so I bought one of these off flea bay eBay Item No. 322204913452 It worked great so I changed my spare key buttons too. I now have 2 fully functioning remotes. |
Well bought one of the fobs in the OP, stripped it down and removed the rubber buttons. Held in with round holes instead of the slots on the original key. Had to make a cut down the centre of the two buttons at the bottom to get it out! Oh well, so persevered and dismantled original key, all went well, transponder fell out, so able to rip out the old one without problem. Fiddled and squeezed the new one into place (easier without the transponder in there!) and got a reasonable fit. Relocated the transponder and plonked the electronics unit back on top. Did up the case.
