Home > Technical (L322) > Free socket in BCU compartment.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
My memory seat is misbehaving like it goes opposite of every input and steering wheel does not move at all so i checked the bcu compartment.
There is a black extra socket in there.
Any ideas??
What can cause these symptoms?*
Post #398012 28th Jul 2016 10:16am
umitbat
Found out:
c0255 main haness to seat harness...
What is this for??
Post #398013 28th Jul 2016 10:28am
C0255 is the plug that takes all the power/signals to the seat, it is yellow so also has air bag control wires as well.... Thumbs Up
Can't help with your back to front seat, maybe try the plug for security and/or corrosion... Pete
Post #398056 28th Jul 2016 3:30pm
umitbat
But it is not connected to any where it is black i guess @haylands
Post #398068 28th Jul 2016 4:28pm
If it's not connected then the seat won't work at all and you would have an air bag malfunction light on...
This is that plug..
It lives here... (seat unbolted)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #398092 28th Jul 2016 6:06pm
umitbat
This one.
Post #398149 28th Jul 2016 9:46pm
umitbat
Post #398150 28th Jul 2016 9:53pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Having stripped my seat down to fix the heating elements I think you'll find that plug goes into the other side of the yellow connector that Hayland has shown. To make life easier the yellow plug can be unclipped from the metal bracket and you should be able to see where it clips in the back.
Post #398158 28th Jul 2016 11:13pm
I remember now, that's not C0255 it's a spare one that isn't used on mine, you haven't filled in your vehicle profile but if you have the same model as mine then it's not used and nothing to do with your issue...
I would guess your problem is the driver's seat ECU which is the switch pack.... either that or the BECM.... Pete
Post #398159 28th Jul 2016 11:34pm
umitbat
Vehicle is 03 td6 @haylands
Thanks for info
I stripped the ecu nothing seems burnt'all clean
Post #398179 29th Jul 2016 8:10am
Maybe worth getting the codes read, it may have logged something to give you an idea.... Pete
Post #398208 29th Jul 2016 10:36am
umitbat
The ecu seems like ok any idea what part is usually faulty?
Post #398210 29th Jul 2016 10:42am
That's the BECM, the ECU for the seat is in the seat switch pack... You can sometimes see a problem but a lot of the time there is no visible damage, the parts fail internally, there are places that can check these ECU's but there is little you can do yourself, that's why a code read may be helpful... Thumbs Up Pete
Post #398214 29th Jul 2016 10:47am
umitbat
Thanks @haylands that ecu is very fine built!
There were no codes.
Post #398322 29th Jul 2016 8:42pm
