![]() | Home > Technical (L322) > 04 4.4 lmost dead. |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Pete (Haylands) is your man for this one, I am sure he will be along at some point if not PM him |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
Not sure how similar your symptoms are but these are the issues I had when my heated thermostat failed and shorted the wiring :
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Read that post and checked fuses thinking " it can,t be this easy" well it was,t. Fuses are fine. Thanks for the sugestion |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8754 ![]() ![]() ![]() |
Don't big me up Ross, I haven't a clue, I can tell you the thermostat fault will have nothing at all to do with engine problems, mine has been disconnected for years and runs fine.... it's not a sensor so will have no effect on fuel delivery etc.... If you want guesses then I'd check fuel pressure at the rail, there is a schrader valve to check it.... If low, could be pump... If not camshaft or crankshaft sensor, also corrosion in the ABS pump socket can cause all sorts of faults.... If no helpful codes then it's good old fashion work through the systems, it needs air, petrol and a spark... you have to find what it's not getting.... ![]() ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Thanks Heylands, I like your thinking, I was just going through some posts on another forum dealing with checking pump relay and connections and of course if the pump is working. I am leaning toward fuel problems as when it first lost power it would run but rough and now it will crank smoothly but sound like it only wants to fire on one cylinder. Will start the journey of discovery tomorrow. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
lots of the early petrol models, suffer from a fuel pump pressure failure. there is a valve to check pressure on the fuel rail, (silver pipe on inlet manifold. ) there is also, a fuel filter underneath, near to spare wheel well. if you have another inline fuel pump, from another vehicle, you could try plumbing it in underneath, and see if it fires up. theres a WIKI on how to change the fuel pump. i did mine, i only changed the actual pump at around £70. unlike others that bought the whole drop in assembly at about £400 -accessed under the rear folding seat carpet. when mine went, it just stopped, and would not fire, however it did start a couple of times, but cut out as soon as the pedal was touched.
Thanks for the encouragement, actually down Under we have what is called " Start you Bitch " I think it works the same.lol |
All fixed |
If you need a new pump soon, which is probably likely, then get one from an X5 and just change the pump itself into the FF carrier, costs about a tenth of the price of a genuine FF one... |
You are right Heylands it's probably due so I can order one in, at least it need not be a panic job and I can look for the best price for a replacement pump. It was most undignified for the ff to ride on the back of a breakdown truck.lol |
It's a Land Rover, it's use to getting a lift home..... |
Pretty well known issue I think, they just fail and need replacing, or fill it up at 1/3 full.... |
you could do no worse, for now...than to carry a red petrol can, with a spare gallon. in the boot. if lawful. |
