Home > Maintenance & Mods (L322) > TD6 Injector Removal - Help !
mercs600
England 2002 Range Rover Vogue Td6 Java Black
As per my previous post , Injector No5 confirmed faulty. So purchased a new one and stripped inlet manifold etc off to gain access and remove it. However it is stuck fast and despite purchasing the BMW M57 Injector removal kit (which doesnt go over the solenoid cap Crying or Very sad )proceeded to attempt removal. Now at the stage where the injector is still stuck fast but without the top part (coil body) Shocked . Can you strip the head down to gain access to remove the fuel inlet part of the injector ? As I can see it it maght need an 8mm threaded bar welding on to the injector and an slide hammer on the job. Just in case I have purchased a slide hammer Wink Any advice appreciated !
Post #397286 23rd Jul 2016 1:43pm
Clive603
England 2004 Range Rover HSE Td6 Orkney Grey
Time to admit defeat and call in a mobile specialist. Such things either come out fairly easily if you follow the book or they are so stuck that you need someone with the experience and extra equipment to pull them out without damaging things. If you do bust something the cost and effort of rectification is vastly more than shelling out for pro.
Google turns up quite a few outfits. Sure to be one not too far away. Hopefully someone on here can point you to reliable firm. There are some right cowboys around.
Clive
Post #397314 23rd Jul 2016 5:01pm
This might provide a few options - some a bit scarier than others:
https://www.youtube.com/results?search_query=bmw+injector+removal .
Post #397317 23rd Jul 2016 5:33pm
But this is the pro way:
gets good after @ 5mins! Laughing .
Post #397323 23rd Jul 2016 5:50pm
Clive603
So easy with the right gear :- . Probably wouldn't even bother to buy tools and try extracting myself. Just strip the injectors down to the inner threads ready and get the pros in.
mercs600 the AP Autodianogstics folk in that video appear to be from up your way.
Clive
Post #397325 23rd Jul 2016 6:04pm
mercs600
Currently soaking in PlusGas . The injector (whats left of it) was moving side to side slightly and also managed to twist it a bit , so , purchased a slide hammer from Amazon , but also purchased the correct removal tool for the injectors of Ebay !The M57 I got from Ebay two weeks ago at a fair cost is useless for our injectors ! It has a top coil pack removal socket which is 27mm - ours are 28 or 29mm ! All tools will arrive this week so in the mean time , Mr Muscle to clean the inlet manifold and a new set of gaskets If I can find some at a decent price/quality. Fortunately the cars not my everyday driver Smile
Post #397339 23rd Jul 2016 7:39pm
mercs600
Forgot to mention regarding suggestion of stripping down to the bottom part of the injector - I can't get access to the part on top of the lower part due to where it is located in the head (the fuel inlet connector part).If I could get that part off I could get the lower part out with the correct puller ! I buy all my own tools and have done for 40+ years as I am an Engineer so they always come in again for something else Smile
Post #397340 23rd Jul 2016 7:42pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I've heard coka cola does a good job on an overnight soak, never done it myself, so don't know.
Post #397350 23rd Jul 2016 9:27pm
mercs600
Also heard this re coke , currently sat soaking with PlusGas as mentioned and by the time I get the pullers (Wed-Thurs) I'm hoping it will be a quick job. Seen the videos on Youtube re removing these injectors and some are really Shocked
Post #397407 24th Jul 2016 11:00am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Try a 50/50 mix of acetone (nail polish remover) and transmission fluid, works better than any off the shelf penetrating oil that I've used over the years including Plusgas and has been proven in tests.
Mix together in an oil squirt can. Shake it well before applying. Avoid prolonged exposure on plastics as Acetone melts ABS.
Post #397418 24th Jul 2016 12:52pm
marcevs72
England 2003 Range Rover Vogue Td6 Adriatic Blue
loosen off the clamp and turn engine over.the compression will pop it out
Post #397465 24th Jul 2016 7:16pm
mercs600
Update :-
I did try the compression method with no luck Sad Anyway ... 5 days with PlusGas and the arrival of the dedicated Sealey injector removal kit for Bosch and Delphi injectors did the job in less than 5 minutes ! Longest part was vacuuming the carbon out of the injector bore , fitting the injector was a 5 minute job and then all covers manifold etc.
Started up and took for a road test - firing back on all 6 cylinders - Happy days Thumbs Up
Cannot recommend the Sealey kit enough ! I am sure it will come in again as that is now 2 out of the 6 injectors I have replaced in 5 years - cost £70 but money well spent Smile
Post #398350 30th Jul 2016 6:50am
Top Job.... I'm with you, spend the money on tools, not someone else's labour.. Thumbs Up Thumbs Up Pete
Post #398367 30th Jul 2016 10:08am
Well done mercs Thumbs Up .
Post #398386 30th Jul 2016 11:44am
Sandyt
+1 well done
Post #398414 30th Jul 2016 2:28pm
