![]() | Home > Maintenance & Mods (L322) > Shiny drivers seat |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3951 ![]() ![]() ![]() |
Although my car has a satin finish Aniline Leather the drivers seat, no doubt due to constant polishing by my sweaty A, has gone a bit shiney. A quick google suggested nothing more than hot water and a magic eraser sponge was needed. So it proved the sponge and hot water lifted the oils etc and the leather is now matt awaiting me to apply some conditioner which I will do later when fully dry.
I never use anything else but a magic sponge for serious interior cleaning , the results are amazing and because no solvents are used you don't have to worry that the leather has been dried out too much . My eight year old steering wheel looks practically as new. 2008 MY Supercharged
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
OK... What's a Magic Sponge ? |
Dunno what it's made of but it's a white block of firm spongy foam which works wonders. Get ours from the pound shop too. |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
my steering wheel leather is quite shiny, i might give this a go? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
They are excellent, I use them all the time but do remember they are basically a very fine abrasive, you can ruin your leather finish if you go too mad, it will take the finish off totally... |
It's just melamine foam , which is very fine and gets into the smallest grain or texture but yes it is abrasive so don't lean on it ,just wipe gently until surface is clean . 2008 MY Supercharged
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Linky no worky |
Probably best just to put "magic eraser" in Google/Amazon/Ebay it's just looks like a little white sponge that works with water only. I would take note of the fact that it is abrasive and use gently. Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
''no doubt due to constant polishing by my sweaty A''
It worse than you think Stan - its my sweaty lycra from cycling |
They do make FF's with engines if you get fed up with cycling....... |
