Home > Technical (L322) > Gearbox judder and cattle grid symptons
stwid
Hi All,
I seem to have the dreaded cattle grid and judder symptoms on my 4.4 petrol 2004 Vogue. I live on the Isle of Wight and wondered in anyone could help with a good localish gearbox specialist.
Many Thanks.
Stuart.
Post #398820 2nd Aug 2016 12:52pm
Weegie
Before you go to a gearbox specialist check the temperature of the discs after a short run. Common fault is sticking caliper, usually rear, which gives those symptoms.
If one is hotter than the others that's where I would start.
Don't touch the discs directly!! John
GAP iiD BT-Sold
Post #398826 2nd Aug 2016 1:49pm
RRPhil
You don’t need a gearbox specialist. Any competent mechanic should be able to replace the torque converter, there’s no need to open up the transmission.
Phil
Post #398830 2nd Aug 2016 2:25pm
stwid
Hi,
Could you please give me any idea how much I should be paying for this.
Thanks.
Stuart.
Post #398942 3rd Aug 2016 7:33am
steviebabes
England 2003 Range Rover HSE 4.4 V8 Epsom Green
In April 2014 I had my cattle grid symptoms eliminated by replacing the torque convertor and the cost was £804.04 inc VAT. The work came with a 12 month / 36,000 mile warranty. 2003 4.4 HSE Epsom Green / Sand. Lovely!
Post #398952 3rd Aug 2016 9:23am
stwid
Hi,
The car has covered 96000 miles is that a good amount for a torque converter on this car ?
Thanks.
Stuart.
Post #398975 3rd Aug 2016 12:24pm
steviebabes
I haven't seen enough threads discussing cattle grid to get a useful average mileage for when it occurs. Of the one or two threads I have seen, I seem to recall them discussing cars at very roughly the 100k mileage point. Mine was done at 142,075. 2003 4.4 HSE Epsom Green / Sand. Lovely!
Post #398981 3rd Aug 2016 12:58pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
RRphil is the man but mine had just started when I firstt got the beast at 119k miles. Changed the fluid and filter and it got much better. Have changed the fluid only 2 more times since. Tranny smooth as can be. 136k miles now. So it might be worth considering this first. My rumble was mostly at lower rpms in 5th. Sounded like driving highway rumble strips that keep you from going off the road if you fall asleep.
Post #400038 10th Aug 2016 10:09pm
stwid
Hi,
Took it to the local Landrover specialist he plugged it into his machine and drove it around, saying there was no faults in the gearbox ecu and it was changing correctly, most probably a fault with the drive shafts. Does anyone have any ideas please.
Thanks.
Stuart.
Post #400345 13th Aug 2016 10:01am
Weegie
Have you tried my suggestion? First post after yours. John
GAP iiD BT-Sold
Post #400348 13th Aug 2016 10:41am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I had exactly the same symptoms as you describe and was resigned to a replacement torque converter, but turned out to be a sticky calliper, front o/s on mine as it happens. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #400365 13th Aug 2016 11:56am
