Home > Technical (L322) > 4.4 tdv8 brakes
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Does anyone know the minimum disc thickness for a 4.4 tdv8 ? Mine are 31.2mm. Dealer has the car so can't check. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #398998 3rd Aug 2016 3:30pm
666tur
I am struggling trying to take the pads off. The two pins in the calliper won't move. I have managed to bend the top one trying to get it out. I assume they are meant to be hit in from the outside. Any ideas what I am doing wrong?
 2012 4.4TDV8 VSE
Post #404342 10th Sep 2016 5:56pm
Yep you are suposed to hit them from the outside with a long punch which fits through the hole. If they are seized in place a bit of WD on the inner holes may free it up a bit. There is nothing that can't be fixed with a hammer😜😜
Post #404351 10th Sep 2016 8:27pm
666tur
Had a hole punch and a decent hammer. Given up. Tried plus gas too. They have not moved at all, just bent. 2012 4.4TDV8 VSE
Post #404354 10th Sep 2016 8:56pm
That's a Censored .
Mine needed a fair tap, but came out eventually! There is nothing that can't be fixed with a hammer😜😜
Post #404355 10th Sep 2016 8:59pm
TomCobbly
I had to cut the pins on mine after trying all of the above to no avail. If you disc cut them at both ends just to the outside of the pads and take the pads out you will find the outside tapered end comes out easily (which is why the pin bends as that moves but the other end doesn't).
I then managed to get a lever arm ball joint splitter on the inner stump and pressed it out. It didn't half let go with a bang!!
I got a replacement fitting kit on ebay for about £12
Hope this helps
Post #404491 12th Sep 2016 11:17am
