![]() | Home > Technical (L322) > Towing Weight for a TD6 |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
3500 kgs.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Second the 3500kg |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Cheers so much guys
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8761 ![]() ![]() ![]() |
Yep,
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1420 ![]() ![]() ![]() |
Have a search on here for the thread about TD6 towing portable lavatories weighing close to the limit - the car is rated to do it but there probably isn't much in reserve at that weight so the gearbox can suffer. Only Range Rovers since 1988 |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
I have been towing a horse trailer (c.1000KG) with 2 warmbloods (c. 1400KG) for about 10 years in a 2004 TD6 with no issues, cant see your stuff weighing more than the 2 horses? |
The person I was thinking of is Miggit and the thread is something like Gearbox D'oh. Only Range Rovers since 1988 |
Will have a look for the post. Thanks so much guys.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8080 ![]() ![]() ![]() |
Gearbox thread - but most of the issue was a botched first fix.....
You could always get a motormover for it if you really wanted maybe even second hand.
I find it very easy on hard ground with a couple of you as you have the grab hamdles at a good height on the front, soft ground/chips etc not easy ![]() |
