![]() | Home > Technical (L322) > First Failure - Cranks but wont fire - Td6 |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 118 ![]() ![]() ![]() |
Well I guess it had to happen.. After just over a year of trouble free ownership the FF has let me down.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
Does point to a fuel pump but you say you have pressure.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I had 2 faulty injectors on my TD6, but that gradually got worse over a few months, and then suddenly in about 4 days wouldn't start.
Hi folks, thanks for the advice so far.
Well its ups and downs. The injectors have all been serviced and cleaned and declared within specification. Suspicion now turns to the High Pressure Pump and regulator. So I'm hoping its the cheap and O-ring fix.
The garage did the 'o ring' fix whilst the car was already in bits from removing the injectors.
Good news, and because it is a red one too |
newman4x4 Member Since: 23 May 2013 Location: France Posts: 1 ![]() |
Hello everyone, I have the exact same problem/error code All 6x injectors were changed.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Is the O ring fix something that TD6 owners should be looking at as preventive maintenance?
MarshallW11 Member Since: 24 Jan 2019 Location: Ottawa Posts: 18 ![]() ![]() ![]() |
Following |
