![]() | Home > Maintenance & Mods (L322) > AC stopped but started working again. |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
On my 2k mile trip returning home my AC stopped blowing cold. I used just the outside air through the system but the volume was low even though it sounded like the blower was trying to move air. After about 1 hour the air flow opened up again so I tried the AC and it was back. Anyone have a clue what might have happened? |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
Hey doclees
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
EmiratesA380 summed that up nicely, thank you.
Thanks folks. I haven't checked pressures. It was blowing so cold i just ASSUMED. It has enough charge. I'll do that today. |
Checked the charge which was smack in the middle of the range. I was driving through some humid states. If I had the windows down and the AC on the vents would blow fog. Do our systems have a fail safe if it freezes up from being stressed?. |
Well before every one rushes to Kwik Fit - a few years ago we have one of our DS4's done - and it was not a good job at all - (before I bought the kit) What I am saying is go and look into this your self - its very easy. If a easy job is easy - sometimes you can do a "PROPER JOB" ( as Guy Martin would say ) - better than and mechanic - and A PIECE OF MIND you have done it properly. I have heard from Mechanics who I know - service cars, due to the time restraints in the workshops do not do all that's supposed to be done and I've heard this about 6 times now - so think on that one Looks to me that some people have more a technical knowledge than others on here ! This Forum - is here to help others in need - remember that one ! |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
It wont freeze up. The expansion valve is thermostatic and only lets through enough gas to keep the evaporator at a stable (ish) temperature. The compressor then responds to the lowside pressure and tunes the amount of refrigerant pumped. |
If you really want to do it properly yourself you need a manifold/gauges, recovery unit, and a vacuum pump. Also scales to measure the amount of refrigerant charged. There is some leeway, but an overcharge isn't helpful to the performance of the system. Worst case if liquid refrigerant enters the compressor it will fail spectacularly. You can't tell the state of charge of a system with a variable displacement compressor by the pressures so just sticking in more gas puts you at risk of overcharging. You should also note that these DIY charge kits put a little outside air into the system each time they are used (from the tube that connects the gas can to the charge port). This is not particularly helpful (as air cannot be compressed to liquid at the pressure / temperatures involved), and the moisture content can saturate the dryer and cause corrosion. Anyhow - your choice. If the car is not worth much it might be worth it to get the aircon going. |
