![]() | Home > Technical (L322) > Sunroof adjustment |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
Sunroof works just fine, up/down - forward/backward no problem and everything stops when it should.
Yeah, gone through all the re-set procedures - it just seems to think that the quarter inch below roofline is where it should be... QUID FACIUM TIBI
Mine sits flush with the roof so that doesn't sound right. No idea how to adjust it though, sorry. |
I seem to remember you can adjust the alignment with a small allen key but not sure beyond that . 2008 MY Supercharged
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8754 ![]() ![]() ![]() |
have you tried this from rave
there is a procedure for the alignment of the glass as well but it is easier to inderstan with the right pics in rave.
As far as I am aware the roof is properly initialized, but I will go through the procedure again. It might be that the panel is sitting too low in the frame or something along those lines - it definitely seems too low in the parked position.... QUID FACIUM TIBI
That second procedure, seems to let you lift the glass in the frame. Had a look on mine, there are a couple of plastic concertina covers on the sides, which you pull clear. This gives access to some screws which can be slackened and the glass pushed up into position if I'm reading it right.👍 There is nothing that can't be fixed with a hammer😜😜
Sounds like that might be what I am looking at - I will give it a go at the weekend.... QUID FACIUM TIBI
