Home > General > What is the difference?
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Please forgive the ignorance, but what exactly is the difference between 4x4 and all wheel drive? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #399442 6th Aug 2016 10:30pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I would hazard a guess at a 4x4 is designed to go offroad and all wheel drive is something Audi keep on about and is used on road cars L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #399443 6th Aug 2016 10:34pm
The end result is the same -
4x4 means that the vehicle has 4 wheels and all 4 are driven.
All wheel drive means that all wheels are driven.
Post #399446 6th Aug 2016 11:02pm
mjdronfield
As Alistair stated, The first 4 in 4x4 means 4 wheels and the second indicates that 4 are driven, so you can have all sorts of permutations, especially on bigger stuff where you can have a 6x4 if it's got 3 axles and only 2 are driven. Or a 6x6 or an 8x8 etc.
I think most of the six wheeled Rangr Rover fire trucks were 6x4....
4x4 seems to now be the general term for an off reader, as already mentioned.... Whereas all wheel drive seems to be used for more road based vehicles, though the terms really state the same thing.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #399469 7th Aug 2016 8:08am
p38arover
Australia
Another difference is that AWD generally means constant 4WD like all Rangies since 1970 (and all LR since the early Eighties).
However, not all vehicles commonly called a 4WD (4x4 in the UK Smile ) are constant 4WD. Many are really 2WD until 4WD is selected. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #399477 7th Aug 2016 9:07am
rar110
AWD normally doesn't have a locking centre diff or low range. They would have some kind of torsion bias centre diff.
I would classify a FL2 as a FWD as the TR locks the rear and centre diff as required, but no low range.
I would also classify a NP Pajero as a FWD as has low range but only a torsion biased type centre diff. ______________________________
Post #399567 7th Aug 2016 10:04pm
FWD in the UK means FRONT wheel drive....!!! Pete
-Click here for Thread-
Post #399577 7th Aug 2016 11:45pm
Spelunker
My previous car, a Frontera had a button to select 'four on the fly' - meant that at low speed you could select between 2 and four wheel drive. Nothing special, but it meant that you could get an immediate feel for the difference as you were driving, flick it into fwd and you literally felt you were driving on rails. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #399662 8th Aug 2016 9:29pm
cliff5.0sc
The difference describes the action of the differentials. An all wheel drive car has 3 open differentials (save for some that have LSD on rear). A 4WD car can lock the center differential. What that means in practical terms is that an AWD car will "slip" and send all the power to the wheel that has the lowest friction. So if your front end or rear end is on ice or a theoretical mew of 0 then an AWD car will not go anywhere and a 4WD will continue to move.
A so called Permanent 4WD like the Range Rover implies some locking ability of the Center differntial. On the 03-06 this is a torsen limited slip. From 06-2012 the center and optionally rear are electronically locking and send almost 100% of torque below a certain amount to the f/r. A range rover with center and rear electronic lockers can move if just one rear wheel has traction via differential power split through electronically contolled diferentials. Adding locking differential across the rear allows the truck to move if the front is on ice and one rear wheel is on ice but one wheel has normal friction. OffRoadRover.com An American Western Range Rover Off Road Blog
Post #400059 11th Aug 2016 4:41am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Along similar lines, can someone explain what a 'Crossover' is? Question
Post #400073 11th Aug 2016 8:31am
mzplcg
Sometimes called a "Soft-Roader" a crossover aims to cross the boundaries between a traditional 4x4 and a car. Older 4x4 vehicles were sometimes thought of as being cumbersome as a daily drive, especially for those who don't really need 4WD all the time and the assocaited size which tended to come with stuff like Range Rovers, Shoguns, Landcruisers etc.
A Crossover was aimed at good internal space whilst remaining smaller outside than a big 4x4 and having some 4WD capability, usually optional. Think of a Volvo XC60 as an example, sort of small 4x4 in terms of looks but without the huge engine and industrial grade 4WD system you get on a LR product. Most were 2WD and a lot more frugal than a FFRR but with a lot of the practicality and space for an everyday drive.
Post #400078 11th Aug 2016 9:24am
PaulTyrer
So I suppose you could say that the Jensen Interceptor FF was an early 'Crossover' car then!
Post #400113 11th Aug 2016 2:34pm
johnboyairey
'4x4' meaning for blonde women.
http://www.dailymail.co.uk/tvshowbiz/artic...lrika.html
Post #400137 11th Aug 2016 4:37pm
RR2008HSE
Some vehicles with part time 4x4 will not have the differentials required for on road driving. You drive in 4x2 mode ON road, then switch into 4x4 mode only on low traction surfaces (off road or snow) when wheel slip can occur.
As others have said, AWD is not for off-roading. Think Audi. It's a great way to get to the ski chalet when there's snow on the road, but not the thing for the Rubicon Trail.
Post #400205 11th Aug 2016 11:13pm
mzplcg
Hardly Rolling with laughter
I had an early Interceptor back in the 80's. I would describe it more like a Gentlemen's Club on wheels. A bijou Gentlemen's Club at that Thumbs Up
Post #400236 12th Aug 2016 8:51am
