![]() | Home > Technical (L322) > cylinder fuel pressure; what is right or wrong?? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
More commonly referred to as "Injector Fuelling Compensation"
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169 ![]() ![]() ![]() |
Hello Mikey,
Positive figures are over fuelling, negative is under fuelling.
Monitored this morning. Cyl. 2 still has 3 and jumped incidentally to 4 and immediately returned to 3 again.
You may find you will have a slight misfire at idle at times
Hi Mikey,
Update on this one. Finally got to replacing injector no. 2 Because injector cleaner wasn't doing anything. With only covering 3000km in the past half year the value of no. 2 increased to +4. So replacing seemed the best option. Fitted new (overhauled by Bosch) injector (came out really easily |
This was from mine when it was faulty and had injector and HP issues
interesting table.
Sorry thats cranking and with the bbs faultmate msv2 |
that makes things clear |
No 😂😂
