Home > General > New car: lots of electrical gremlins
pdt
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi all
I have been picking issues off one by one, but alas I wanted to share and hopefully gain some ideas from the community!
Car: MY06 Supercharged
Mileage: 48k
Issues:
1. Reverse camera just gives a black screen - appears to function but not get video feed
2. Sat Nav has the 'GPS' logo cross out in top left of screen when in the Nav System. Makes the whole thing pretty much useless as it doesn't move or change map position!!
3. The TMC logo on the top right seems to come and go, that is, get cross through and not.
4. Checked levels under bonnet today and noticed the coolant was frozen - is this normal?
Tried many different things recommended on the forums to rectify items 1 & 2 without luck.
Is there an independent specialist that serves West London? Otherwise, it will be off to Lookers!
Thoughts / ideas welcomed!!
Cheers
pdt
Post #39895 28th Nov 2010 6:29pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
reverse screen
Intrested in whether you get any news - my screen is intermittantly black, in fact for the last month - until last fri when it jumped into life. Left the house some 20mins later and is again black. Haven't managed to get back to the UK to get it sorted out yet - i suspect a loose connection some where but for the life of i cannot see where.
Post #39897 28th Nov 2010 6:42pm
Fox
Re: New car: lots of electrical gremlins
Frozen? Shocked
With the current weather you need to drain off the coolant and get some fresh antifreeze mix in there pretty quickly.
Freezing coolant can do a whole load of damage. you really don't want to go there.
My concern.. .If the last owner was running the vehicle without enough (or any?) antifreeze did they actually look after the car at all?
Post #39901 28th Nov 2010 6:52pm
Harris-Mayes Country Cars (Ex Main Dealer for Land Rover and very experienced)
Unit 2/Woodcock Hill Est/Harefield Rd
Rickmansworth
Hertfordshire, WD3 1PQ
01923 711800
Kings Langley Land Rover (Independent LR Garage owned by a Main Dealer but Indy prices)
Unit 5 Sunderlands Estate | Church Lane | Kings Langley, Hertfordshire | WD4 8JU
http://www.kllr.co.uk/7601/kingslangleylandrover.htm
Used both of the above and very good value for money near J18 & J20 of M25.
Post #39905 28th Nov 2010 7:22pm
pdt
Hi Fox
Thanks for that.
Figured as much.
Oddly - it is the right 'pinky' colour you would expect...
Will do another check to make sure that it was frozen or just me not knowing what I am looking at.
It could do with a little top up...
How does one do the drain off of the coolant? Easy job?
Cheers
pdt
Post #39927 28th Nov 2010 9:44pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Sorry to hi jack is any specific anti freeze recommend by RR?
Post #39937 28th Nov 2010 10:04pm
pdt
Hi Paul
Castrol Antifreeze SF
In a 50:50 dilution...
Cheers
pdt.
Post #39946 28th Nov 2010 10:24pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Sorry am I being an ass?
Why not take the car back and get these issues sorted?
You say new car?
If mine had anything like this lot wrong it would been back on the dealers forecourt for fixing. 15MY SDV8 Vogue SE
Post #39949 28th Nov 2010 10:29pm
daveo
hi pdt, where did you buy it from, was a dealer.... V8 facelift Range Rover Autobiography 22" wheels.
Post #39951 28th Nov 2010 10:38pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
pdt
I have the same problem. Would like to know if there is a solution instead of having to shell out 400 GBP for a new rear view camera! '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #39962 29th Nov 2010 3:05am
sleepezy
3 - My TMC comes and goes pretty regularly - I guess dependent on whether / not it's in a 'Classic FM' reception area (ie TMC info feed channel)
Post #39966 29th Nov 2010 10:27am
The "PINK/ORANGE" 50/50 Antifreeze from Halfords is pretty much the same stuff as the LR Rip off.....
Post #39967 29th Nov 2010 10:32am
pdt
Hi guys
It was a private purchase unfortunately! Buyer beware and all that...
Such is life...
An update:
The coolant wasn't frozen... it was just me being a bit perplexed with how the overflow return come in at the top and is all pink!
Looked a bit lower and saw liquid moving when I tapped it!
Tried the nav diagnostics last night... (753 thing) and there are no error codes showing!
I am thinking the antenna must be stuffed...
Going to play a bit more tonight and see what i can work out...
TMC is all happy again, must have been temporary reception issue.
Camera - still f3cked!
Going to drop the engine oil out of it tomorrow, even though service not yet due. Cold weather starts... going to drop in Mobil 1 synth I think...
Cheers
pdt.
Post #40013 29th Nov 2010 2:43pm
