![]() | Home > Maintenance & Mods (L322) > Preventative failure question... |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
M62 V8 4.4 Petrol.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2234 ![]() ![]() ![]() |
Hi rr - not really nosey just clatters for a second or two on a cold start..? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
From personal experience, of buying an early BMW engined v8 as a spares and repairs, with a near knackered engine. (140k) my symptom, and a few I've seen, as being interested in the failure, is the timing chain guides. Not the chain itself.
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I'd sum it up by saying lack of proper maintenance. These are higher maintenance beasts and some of that maintenance is expensive such as the those timing chains and guides. My 1995 Jeep wrangler was all things opposite the RR - cheap and easy to work on. |
Ok - so I'm 99percent sure I just have the couple of second vanos rattle I googled m62 chain guide figure and it sounded like a whine noise which mines not doing (not saying anything wrong with my car here at all btw) but it's at 140k where I've seen the failures - do people on here just change them or do they usually wait for a sign of failure - I'm guessing a horrible sound change from the engine? |
If you have start up vanos rattle, you could actually cure it, by changing the solenoid return valve seals.
Like Johnniyairey said. I would add that the solenoid check valves are cheap and made a big difference with start up rattle for me. I also use 10w/30 since I don't live in the arctic. I use the rattle as an indicator of oil health. More rattle = dirty or old oil. Changing the oil filter every 3k miles helps too. When ever Rockauto sends me a notice of supplier close out I get 10 or more for $1.50 each.
Hi guys - thanks for the advise I will keep an eye for the bad sounds and do the vanos check for now - those guides sound way to involved and much of a diy for me so may hold fire unless something sounds bad or oil light on... Also have already done the stat mod so hopefully helps.. I'm running 10w40 not sure if that's relevant
Fully synthetic oils are rated for 15k miles or so it is said. No filter out there is good for more than 5k miles. I haven't found a cartridge type filter good from much more that 3k miles. 5 min job on these urban tanks. |
Really on the filter? I've got an m6 I do oil and filter at 10k and its comes out solid and a 330 which is exactly the same... |
I'm not sure what you are saying when you say the oil came out solid. As for filters there are a number of independents and companies that have done the tests on at what point the filter can't hold anymore particles. That leaves the oil to contain the particles.
