![]() | Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
No you don't need to trim the toe eye the cover fits nicely Matt Current 2012 Range Rover 5.0L SC Ultimate Edition 2012 Range Rover 4.4L TDV8 Autobiography 2010 Range Rover 3.6L TDV8 Autobiography 2003 Range Rover 4.4L V8 Bespoke Vehicle Inventor of the retro fit paddle shift and many other modifications. Creator of the custom 2010+ RR MK4 splash screen. Creator of the Range Rover CarPC and lots more! Founder of Range Rover Owner rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner |
Can you send me the links to the rad cowl and the crash bar info, I didn't change the cowl or do anything to thdo crash bar Matt Current 2012 Range Rover 5.0L SC Ultimate Edition 2012 Range Rover 4.4L TDV8 Autobiography 2010 Range Rover 3.6L TDV8 Autobiography 2003 Range Rover 4.4L V8 Bespoke Vehicle Inventor of the retro fit paddle shift and many other modifications. Creator of the custom 2010+ RR MK4 splash screen. Creator of the Range Rover CarPC and lots more! Founder of Range Rover Owner rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Hi Matt
Hi Matt did you get a chance to check going to make a start tomorrow eve so would be good to know - many thanks! |
Just watched the video, I didn't fit the new airflow guide or head light supports the existing ones work fine and I haven't found that the airflow guide is required
Hi Matt - today it began and I must say thanks for the guide it was very useful...
Glad your making progress on your facelift.
Hi all - I am pretty much done but really need to know what holds the washer jets as the fall straight through and there's nothing to push the clips into.
bump - could really do with the part knows if anyone knows them and how they affix? |
I have been looking for you, there is no part listed in the Land Rover parts system. I'm starting to think these must come from the factory already attached to the bumper. Might be best to contact Dan at Duckworths to see if he knows if it is a part you can buy separately
Josh Wyatt Member Since: 10 Jan 2011 Location: Oxford Posts: 77 ![]() ![]() ![]() |
These clips hold the washer jets into the bumper...
Thanks for looking so far Matt - hopefully Dan will chime in...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16391 ![]() ![]() ![]() |
Dan, the inner panels you are searching for are fitted to the bumper in factory and get removed by companies like Overfinch for example to fit to their own bumpers at point of upgrade/fitment... This renders the “old bumper” unserviceable as a factory standard item...
Cam-Tech-Craig or anyone else - do you have a picture of them - i wonder if they could be manufactured with a jigsaw and some body glue?
