Home > Technical (L322) > Electronic Parking ,Brake
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Just passed MOT ( equivalent ) a couple of months ago and applied the EPD recently and nothing happened except for the PARK BRAKE not available warning. IID tool tells me it the module and no sounds from the unit itself. Any ideas other than replace. i have read all the posts about freeing off the adjuster but mines not making any noise so I don't think it's over extended
I had new rear discs , pads and shoes fitted today and shoes were ok
Thanks in advance 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #399356 5th Aug 2016 10:53pm
dolph34
Bump 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #399863 9th Aug 2016 10:37pm
kbald
Have you tried to see if there is any tension on the cables for the hand brake going to the calipers when you apply the Epb? If not it could the electrical module. There is also a park brake recalibration in the iid tool menu you could try! I was told by the Indy if the electronic module needs replacing and calibrating it's quite expensive so hope it's not that! You could also try a battery reset too!
Post #399891 10th Aug 2016 7:40am
dolph34
Thanks for the answer , no tension on cables so I'll try the electrical module I did see a few on EBay and it would be a far cheaper fix. I tried the IID tool reset but it didn't work. Thanks again 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #399892 10th Aug 2016 7:43am
kbald
I'm assuming you have also tried the latching and unlatching process on the iid tool too see if you get any movement there??
Post #399893 10th Aug 2016 7:45am
dolph34
I haven't tried that. I didn't see that option. I'll have a look later. Thanks 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #399919 10th Aug 2016 12:00pm
dolph34
Hi. Anyone removed the EPB ? And if so how ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #402167 26th Aug 2016 11:01pm
dolph34
Hi. Looked through the workshop manual ( thanks to wiki ) on how to remove the EPB and it seems dropping the rear suspension is the way to go. I'm now looking for a wiring diagram for the EPB for my 2007 that's shows the EPB wires. I e looked through the Wiki offering but it was printed in 2001. Any pointers on where to find one please ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #402600 30th Aug 2016 3:12pm
