![]() | Home > Technical (L322) > Cold Starting Diesel? |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Mine is the same, starts, just feels a bit rough.
My 2006MY Vogue SE Supercharged is not liking the cold either. Its starts first turn but immediately dies unless you give it a touch of throttle. It is then a bit lumpy for a few minute while warming up. First few seconds it smokes just a little too.
I wonder if the filling stations have changed to winter fuels yet? |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Not noticed any difference here, but think it's only been down to -4.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
Hi Gaz, don't know if it helps (sadly my LTB list is on my laptop at home) There was a software update for the SC which dealt with the weak 'catch' on startup and rough idle for a couple of seconds. I only found it because I thought it was Voltage related but still got it after I changed my battery. The symptoms were usually worse in cold or if it was left standing for a long period and basically on turning the key the starter would crank then the engine would hesitantly catch and huff and puff for a second or two until it settled. May be worth a look. |
When you get home could you post the LTB number please. Very helpful thanks. ![]() |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Well having been out in the 110 earlier... where you have to manually hold the glow plug position for about 15 - 20 seconds before considering a very lumpy start it is still pure luxury.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
If the battery hasn't gone flat (again, due to the cold and me being too lazy to replace it at the moment - the trusty MX5 and some jump leads to the rescue), my diesel takes a few more revolutions on the starter than normal to get it to fire up ( I always wait for the glow plug light to go out !), and then apart from a bit more clattering than normal from the engine, runs smoothly straight away. .
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
I use Wurth winter diesel additive as a precaution on both my cars. So far no problems at all, not even on initial start up...
-8 here last night and I started the TD6 without waiting on the glow plugs heating. nice and smooth on start up and no misfire |
@Gaz:
