![]() | Home > Off Topic - Other Cars > Things I've learnt from owning a Defender...... |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
I learned that for defenders , it was easier to just replace the whole bar including both ball joints, rather than fighting trying to undo a single ball joint. V8 or else ... |
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 309 ![]() ![]() ![]() |
Finally sorted and back together. Drive home was quite boring really ......it goes where I want it to go now instead of randomly drifting towards the nearest tree or hgv. Apparently you can do a modification using a discovery drop arm which is ten times easier to work on. That or just buying a new drop arm and joint complete as you say. Lesson learnt! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
When I had my Defenders I found that even one simple job seemed to create 5 more.
There, I fixed that for you ![]() |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
Early ones had a drop arm with the ball joint in the arm (can be a pain to do). Later ones had a conventional tie rod end, dead easy to replace.
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
1. What do you mean I'm shouting? (damn thing made me deaf)
Aha the ripped pocket.....yep done that. Well it felt like I'd tore myself a new ar@@hole one time.
