Home > General > Fuel tank reserve?
Fox
Fuel tank reserve?
On my Td6, I could run it until the range was 0 and it took 102 litres of diesel.
On my TDV8 I am running it until the range is 0 and it is only taking 93 litres.
Supposedly the fuel tank is the same size, which would suggest the Td6 didn't keep much in reserve at all, but the TDV8 keeps a few gallons.
Is it just my TDV8 that does this and keeps so much spare or have other owners noticed this?
Post #39999 29th Nov 2010 1:43pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
I have only tested the reserve tank range once - when I first got the car. The fuel reserve light was on but I kept my eye on the on board computer and I kept going.... The car suddenly came to a stop even though the computer still showed a range of 35km!! Not very accurate is my conclusion! '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #40008 29th Nov 2010 2:24pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
When i set off from my house on Friday, the Range was -- . Had no problems the few miles to the petrol station, but i didn't brim it. Next time i play the fuel lottery, i'll brim it to find out. Our local petrol station has a max delivery of 95L though.
Post #40009 29th Nov 2010 2:27pm
Fox
So does mine, well that or 99 litres, but once they get used to you filling it up all the time it can be overridden by the staff.
I did once put £50 in and they asked why I didn't fill it up. Laughing
Post #40011 29th Nov 2010 2:35pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I just fill mine up when light comes on, which is abour 3 gallons and 54 miles to go. I couldn't risk running it until 0! Shocked
My luck, I'm bound to run out of fuel. and it's not an easy car to push! Laughing
Post #40012 29th Nov 2010 2:38pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I've pushed 100 litres into my TDV8 and the bill was £119.90. Range was still showing 25 miles or something like that. Never seen the range at zero even though I'm usually tempted to play the fuel light lotto. Most pumps won't go past £99.90 (ish) or 100ltrs on some types, but the most modern ones will happily sail through this as they have a five digit £ display. Not many of them about yet but they will be appearing everywhere eventually. Crying or Very sad The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #40014 29th Nov 2010 2:46pm
Do they not use hand cranking pumps in Scotland Laughing
Post #40018 29th Nov 2010 3:15pm
JMC
When I said that I'd pushed 100 litres in, that is of course exactly what I meant.
Meantime, I also filled up with Esso Blue parafin for the new fangled heaters we have at home and I was exceptionally lucky to receive a couple of exquisite crystal glasses from the man behind the counter. I'm sure the whisky from my garden still will taste much better now. Rolling Eyes The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #40026 29th Nov 2010 3:48pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Whilst I never fill until the light comes on, I am too nervous to push for real fuel light lottery. I have also been told that running the tank very empty is bad as it encourages all the dregs to be sucked into the fuel filter. Sounds like BS to me (the fuel feed will be from one of the lowest points in the tank) but I did have a big problem on one of my first Astons as the fuel pumps were very susceptible to damage.
Post #40030 29th Nov 2010 4:16pm
Fox
I only do it as when the light comes on I can only get about 80 litres in. So I know I can go a bit lower...
With the TDV8 even when range hits 0 I still have enough for about 50 miles. Shocked Although I'd not go beyond range = 0.
Post #40037 29th Nov 2010 4:40pm
Avi
Fox
Does it actually say Range 0 ? , as i have only ever seen "Range -- ". I've never been looking to see if it went to zero first.
Andy
Post #40053 29th Nov 2010 5:21pm
Fox
No, --- I take as 0. It does show right down to 1 though sometimes. Other times it jumps from 4 or 8 to ---.
Post #40070 29th Nov 2010 6:33pm
It's not a good idea to let the tank run dry, if you do the fuel lines and filters pick up all the crap from the bottom of the tank. I've also read that it can damage the CAT when you run out of fuel.
Post #40203 30th Nov 2010 5:22pm
Fox
Agreed. But at range 0 it has 10% still left in the tank. Thumbs Up
If I refuel at 50 miles range it's still 20% full... feel like I was stopping every five minutes!
No wonder I could never have an SC. Laughing
Post #40213 30th Nov 2010 6:28pm
daveo
hi, i have the 4.4 petrol and it will run out when it says around 25 miles left, can this be reset to correct it, not that i let it run that low any way... V8 facelift Range Rover Autobiography 22" wheels.
Post #40219 30th Nov 2010 7:13pm
