Home > Technical (L322) > Heated screen fault
Andy
Heated screen fault
Only the passenger side is clearing - does that mean I need a replacement? I read somewhere that the heater element is in two halves. If so, are they controlled by seperate feeds? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #40015 29th Nov 2010 3:03pm
dan_uk_1984
There are 4 connections to the screen I believe. + & - for each side. It might be worth finding where these are exactly and checking the connectors are present and correct.
Have you had a replacement screen at some point? Maybe now is time for that stone chip?
Post #40022 29th Nov 2010 3:26pm
From what I have seen during screen replacement the internal side strips pull out revealing the heated screen connections....
Post #40028 29th Nov 2010 4:09pm
