Home > Maintenance & Mods (L322) > Power Window Auto-Wind Problem
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi there,
My Drivers window has stopped working on the Auto-wind. I.e. When you raise the window, there is a second click where the window should auto wind until it's shut. It still works in the downward auto-wind position.
On the day it failed, I noticed that when I was driving at speed with only the drivers window open, I set it to close fully on auto-wind with the button, the window raised to the top and then reversed down as if something was trapped and the pressure sender picked it up. I assumed that it was the wind / cabin pressure of my slightly high speed. Then later I had tried it with the upward auto wind, the window would not 100% close amd and I had a bit of wind noise.
All other Windows are working fine and drivers window ok on downward auto-wind.
Any ideas what has gone wrong ?
Thx
Post #400459 14th Aug 2016 8:37am
Rob99
Have you tried resetting it?
Close the window completely and let go of the switch, then pull switch up for a couple of seconds.
Worked on mine when my passenger window wouldn't autoclose. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #400460 14th Aug 2016 8:44am
bwelton
Worked !! Thanks so much.
Post #400470 14th Aug 2016 9:47am
Rob99
Glad to help Thumbs Up Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
Post #400490 14th Aug 2016 1:55pm
