![]() | Home > Technical (L322) > Just when it was all going so well.......EGR issue..!! |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Sounds like the same problem I had in France recently. I had the restricted performance with the the same error code. It appears that this sensor error is a common fault with the 4.4 tdv8. Mine was replaced by a main dealer whilst in France. Strangely enough they also found that the plastic inlet manifold had split and this also had to be replaced. |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Right, have a look at http://www.fullfatrr.com/forum/topic38739.html and particularly http://www.fullfatrr.com/forum/topic38609.html
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
Thanks Buz1500/GLM
My best guess would be this.....
Well, would you |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
LR Assistance were brilliant when I used them in May.
That's very impressive service. |
