Home > Technical (L322) > 07 RR Airbag module location.
jam220
United States 2007 Range Rover HSE 4.4 V8 Bonatti Grey
I am trying to locate the airbag module, I don't see it under the console. I have the console pretty much all the way out but i don't see it. All i see is the blower motor, vent tubes and the shifter assembly. Anyone have any ideas where exactly under the console it is?
Post #400545 14th Aug 2016 11:18pm
From memory Whistle Its under the carpet thats under the console Thumbs Up
Post #400546 14th Aug 2016 11:48pm
jam220
thank you that was the only other place it could be. Please let me know when you are back from vacation I still want to order the headlight wires
Post #400553 15th Aug 2016 12:59am
jam220
I moved the carpet towards the front of the console I still don't see it. =.. the module is decent size cant really miss it but I don't see it
Post #400581 15th Aug 2016 12:18pm
info should be in the WM... ... - .- -.
Post #400586 15th Aug 2016 12:38pm
jam220
Work Manual (WM)? I dont have manual but i got some diagrams which shows its under the console i keep at it. Thank you
Post #400627 15th Aug 2016 7:29pm
Just had a look in the WM (Workshop manual) all it says about it's location is...
The RCM is installed on the top of the transmission tunnel, beneath the transmission gear selector lever assembly, and controls the operation of the SRS.
Nothing about it's removal...
Workshop manual can be downloaded from the WIKI.... Thumbs Up Pete
-Click here for Thread-
Post #400635 15th Aug 2016 8:23pm
jam220
thank you sir ill keep digging, I was trying to avoid taking out the console completely but seems ill have to do it.
Post #400661 15th Aug 2016 10:33pm
jam220
ok found it, three of the nuts that holds down the shift assembly is exposed is the 4th one have to be accessed through the bottom of the car?
Post #400670 16th Aug 2016 3:53am
jam220
UPDATE: Got it thank you all
Post #400862 17th Aug 2016 3:49pm
Thumbs Up Thumbs Up Pete
Post #400871 17th Aug 2016 5:22pm
