![]() | Home > Technical (L322) > Pre Heater / Timed Climate problems |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
Is there definitly one installed?
Nice picture are you an amature photographer?
Search google for "Webasto Lock Out" it's worth checking to see if this is happening to you.
If you have Aux heating then you have it. If you have Aux Ventilation then you dont. ![]() |
Lawton 2OCJ Member Since: 29 Nov 2010 Location: Skipton, North Yorks Posts: 27 ![]() ![]() ![]() |
Yes definately have a remote which statrs everything off, I'm guessing its not igniting?? RR Vogue 4.4V8 |
Its my full time job actually ![]() ![]() |
Normally a voltage issue. Or is with the ones I have had experience with Shame mine does not have it. 15MY SDV8 Vogue SE |
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 ![]() ![]() |
Just had same problem with my Webasto heater on a TD6 - interior blower running for 2 mins and FBH making noise but not igniting and then locking out. Had it tested on Autologic and deffo the heater unit and not the solenoid pump which lives on top of tank under back seat. New full unit approx 1060 +vat from stealer, no separate parts available. Had the unit removed and took it to a Webasto service agent. It wouldn't run on his test rig or diagnostics as it was to test generic Thermotop Webastos which have a control ECU which works off a 12V trigger, the Webasto on the RR has a RR specific ECU which communicates with the canbus via baud rates.
You're not a million miles away, where was the webasto agent?? RR Vogue 4.4V8 |
Mellor AutoElectrics, Ossett - young guy called Stuart. Nice lad, v helpful but unfortunately couldn't test the ECU.
You'll struggle to find a 2nd hand petrol one though |
Thank you, my indie's getting some new diagnostic softare next week which has the pre heater bits on it next week. Hopefully we will be able to tell from this weather its the ecu, solenoid or unit.
Was initially going to take my FBH to Leyland Autos at Preston who are an authorised Webasto Service Agent - look on Webasto site - as a guy who drinks in our local is a Webasto rep but he wasn't sure if Leyland repaired RR ones. Unfortunately when I ended up having FBH removed to attempt to repair it, the Webasto service guy at Leyland Autos was on hols so I went elsewhere. Saw the rep in the pub last night - he's since spoken to the service guy at Leyland Autos and apparently he's familiar with RR FBHs and apparently can test and repair if removed from vehicle. Looks like he might be your man. |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2054 ![]() ![]() |
Just down the road from me |
