Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless Iām not at home, in which case Iām somewhere else. Posts: 6669 |
They won't work. Got - 2017 SDV8 Autobiography in Loire Blue
19th Aug 2016 9:10pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Is that an mot failure I thought they had to have headlight washers and auto level? |
19th Aug 2016 10:08pm |
Bit late to worry now it's all done just so I can prepare lol |
19th Aug 2016 10:10pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7941 |
Never had an MOT tester load the boot with half a ton to check if the self levelling headlights work so don't lose any sleep over it Pete
19th Aug 2016 10:28pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
You have EAS so as far as an MOT is concerned thats self levelling |
19th Aug 2016 10:31pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Hi to all.Thanks to this amazing step by step guide i have managed to facelift my td6 but without touching the headlights water pump/water reservoir tank.By reading the new posts found quite interesting the idea of just replacing,if possible,only the headlights pump instead of the all water tank/3 pumps.
24th Aug 2016 4:01pm |
Hi akis
24th Aug 2016 8:47pm |
Excellent.Looking forward for your reply
25th Aug 2016 8:50am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Its looking very smart!
25th Aug 2016 10:17pm |
Right two things I need to raise - firstly this high pressure water pump...
3rd Sep 2016 9:50pm |
Have you crossed over the 2 wires from the old LH side headlight washer connector wire?
3rd Sep 2016 11:38pm |
Hi Matt - so I was meant to do something with the wires that went to the headlight wiper unit? I just unplugged and left that - I literally unplugged the old unit plugged new one in and hoped for the best - so what do I need to do? Cheers! |
4th Sep 2016 9:20am |
Grille needs Black Surround... |
4th Sep 2016 9:39am |
On the old LH side washer/wiper connector you need to cross the switched live (not the permanent live) to the ground in the connector. The pump will then work when the headlights are on it will spray every 5 wipes. Matt Current 2012 Range Rover 5.0L SC Ultimate Edition 2012 Range Rover 4.4L TDV8 Autobiography 2010 Range Rover 3.6L TDV8 Autobiography 2003 Range Rover 4.4L V8 Bespoke Vehicle Inventor of the retro fit paddle shift and many other modifications. Creator of the custom 2010+ RR MK4 splash screen. Creator of the Range Rover CarPC and lots more! Founder of Range Rover Owner rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ā YouTube.com/RangeRoverOwner |
6th Sep 2016 8:28pm |
