![]() | Home > Maintenance & Mods (L322) > Front suspension clunk |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8622 ![]() ![]() ![]() |
As I say the bushes wear out but the balljoints have little movement, unlike a steering arm, your control arm has the ball joint built in, the other ball joint in the hub is a pain to get out and I bet it will be fine, mine is after 14 years and 152,000 miles.... |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
OK I will go with control arms and endlinks for now. Thanks all. |
Thanks. Yes drop links identified as primary/only source of clunk. Parts on the way. No clunk any other time but those slow rolling bumps like speed bumps. I'm still going to try to mount my video camera under there to document just what is happening. I'm sure what northernmonkeyjones says is correct and my control arms are on the way. I'd just like to find a way to visualize the ball joint or bush play while on the vehicle instead of after the part is off.
DM993tt Member Since: 23 Jun 2016 Location: NY Posts: 4 ![]() ![]() ![]() |
pretty sure you won't be able to "see" what is causing the noise on the drop links. Just make sure when you put the new ones on you use an 18mm spanner to hold the back side of the joint when you tighten the nut. There are 2 flat sides that fit an 18mm spanner just inside the little rubber boot. If you don't get those real tight you'll have the same clunk. Its a very simple fix to a very irritating noise. I had the car on a lift, but I'm pretty sure you can do it on the ground with the wheels on. |
I'm beginning to see the what and why about these ball joint control arms. Just got mine today and out of the box I can't move the ball joint at all which is unlike any ball joint I have dealt with in the past. |
Update:
2nd update: All front endlinks, upper ball joints and lower control arm/arms done. Clunk ended with right side endlink replacement. Shimmy still their. Next going to have balance of tires checked. It wasn't a total waste to do all this premature. I did find the control arms bushings a bit dried out. |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Your query about re using the bolt on what you call the "Tie Rod" I reused the bolt and nut, it was in perfect shape.
It's not that I call it a tie rod. RAVE does.
Goodo,
Bolts are generally less than $10 us unless you go dealer. I would imagine as long as you don't plan on any real off road adventures the old bolts would be safe to reuse but don't torque angle then again. As we move into winter here in Pennsylvania pot holes get rather large and abrupt. I feel better with new bolts even if no one has heard of one breaking. |
So to sum it all up all ball joints were within serviceable limits. The bushing on the control arms were just starting to break down. The right sway bar end link was worn and caused the clunk. The upper ball joints were a pain to remove with an air chisel. I need to make a puller. As of now all ball joints and both end links are new. Front tires ballanced.
Following up on this. As of this moment the following parts are new with between 0 and 10k: both inner track rods, both tie rods, both upper ball joints, both end links. I had just done both inner track rods because the alignment/mechanic garage said the right was worn and causing my clunk. They were obviously wrong. There is no play in the half shafts or the outer track rod ball joints.
olliecat2 Member Since: 30 Jan 2018 Location: FLINTSHIRE Posts: 13 ![]() ![]() ![]() |
Apparently its well known that the Dunlop strut is known to fail in the top of the strut if it has been fitted as a replacement to the OEM. Mine does it, and unfortunately only cure is to replace whole strut. |
