Home > Maintenance & Mods (L322) > Aircon/climate control
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
OK, so the beast has had the A/C emptied; checked for leaks and refilled without problem
However, it is only icy cold in the max setting. Using auto setting seems to add warm or ambient air (or maybe slightly cooler)
Am I not setting something right or could there be an issue?
Post #402148 26th Aug 2016 8:02pm
Thumb wheel below center vent turned to blue...??? Pete
Post #402173 27th Aug 2016 12:46am
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Is it colder with the vehicle moving but failing to chill when the stationary? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #402176 27th Aug 2016 6:35am
berkshirelad
Yes, all the way
Post #402208 27th Aug 2016 12:16pm
berkshirelad
No, moving doesn't seem to make a difference.
It mat just be me, but I would expect an icy blast given the weather we are having to bring the interior temperature as quickly as possible. Having the window open when moving seems cooler.
It had a new pollen filter at the same time as the re-gas
Post #402209 27th Aug 2016 12:19pm
It will always be a bit cooler on max as this recirculates the air inside so it is chilling chilled air after a while....
Try it on manual recirculation and see how that is... Thumbs Up Pete
Post #402224 27th Aug 2016 2:45pm
