![]() | Home > My Range Rover > None of your rubber band tyres here . . . |
2nd Rower Member Since: 24 Sep 2009 Location: Upside Down Posts: 62 ![]() ![]() ![]() |
Did they fit straight on; or did you have to do any mods to get them to fit?
Compomotive 18" wheels will fit over the four pot Brembo's without having to move the counterweights like on the Sport but they can't fit over the six pot Brembo's fitted to TFT dashboard cars after 2010 if that makes it clear . 2008 MY Supercharged
I think that makes it clear thanks! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2734 ![]() ![]() |
The MY10 3.6 TDV8 didn't get the 4-pot or the 6-pot Brembo brakes, instead just a 2-pot sliding but I don't know if the Compomotives fit over them. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Thanks Graeme. So JLR changed brakes for the facelift 3.6, and used the same brakes on the 4.4 tdv8?
No, only the MY10 TDV8 (3.6) got the lesser brakes as the 6-pot Brembos were fitted to MY11 TDV8 (4.4), the same ones as fitted ot the 5.0 SC. The MY11/12 5.0 na got the same 2-pot floating callipers as fitted to the MY10 3.0 D4, but different callipers to the MY10 L322. |
GoE have just replied to my query stating that the 18" will fit the 2010 TDV8!
To be honest you won't have a problem , if you car is as you describe, ie a 2010 TDV8 for that year the Brembo brakes were removed and a simpler sliding caliper was fitted , when they were changed again the next year they went up to the six pot Brembo which are the only size that won't work . 2008 MY Supercharged
