Home > Maintenance & Mods (L322) > L322 Fog Lamps
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
L322 Fog Lamps
I've been going over my Vogue today and started looking at the fog lights because I was getting a "Check Fog Light" warning on the dash. Sadly one connector has been busted and glued badly back together (glue had let go, hence the dash warning), but the fog lights themselves are badly corroded internally so 95% of the silvering has come off. Prices for replacements seem to be nearly £200 a pair Shocked
Are there any alternatives ? I have found Range Rover Sport aftermarket ones at about £80 a pair, and the mounting points seem to be the same to fit the bumper - but they take H11 bulbs. Will fitting these trigger a fault/warning as the originals are H7's I think (I have to repair the wiring to one fog anyway, so could splice in the correct connectors).
Post #402336 28th Aug 2016 5:40pm
Hmb
England 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Don't quote me but I'd guess as long as voltage/wattage is the same it should work 2010 Overfinch 3.6 V8 FFRR gone yee haa
2005 Supercharged 4.2 V8 FFRR (written off)
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #402340 28th Aug 2016 6:21pm
Yes the foglights are the same as the Sport as in fact are the foglights fitted into the Discovery 3.
Bulb wattage will not cause any problems.
I seem to remember seeing some aftermarket led foglights that will fit for about £40 for the pair but unfortunately I can't find them at the moment.
Post #402341 28th Aug 2016 6:36pm
Ask Stan when you pick the wiper up, he found some very cheap LED ones that fitted great... Pete
Post #402346 28th Aug 2016 7:17pm
Biffo
Thanks, I'm seeing Stan shortly so I'll ask him. In the meantime I've ordered some of the H11 type aftermarket ones I mentioned above, and some H11 connectors to splice into the loom.
I did manage to strip the old ones down, but they need re chroming, which is an arm and a leg in itself Shocked I toyed with the idea of relining them using aluminium foil, but thought better of it !
Post #402425 29th Aug 2016 2:55pm
NeedForTweed
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Barolo Black
Just re-igniting this old thread rather than starting a new one…
I have a 55 plate 4.2 supercharged - will the RRS/disco fog lights also fit? There seem to be a few unique…quirks to the SC. Have bought parts that say will fit then don’t - could be sellers just lying though!
Cheers
Post #630260 1st May 2022 8:31am
Unfortunately it would depend on the exact date your vehicle was manufactured. The fog lights run from 2002 to 2005 and then 2005 to 2009. You are in between.
If you were to take out one of your lights and post a picture it should be possible to identify which one you need.
You need to show the fixing points to identify. Thumbs Up
Post #630262 1st May 2022 9:01am
NeedForTweed
Thanks for the reply - registration is 1st sept 2005 - will check the vin later. I don’t have terrain response. Seems to be very hard finding parts listed for my model as you say, it’s in the middle of the swap!
I will try and pull the lamp out today and post pictures
Post #630263 1st May 2022 9:07am
If the fog lamps are original they should each have a part number printed on them. Thumbs Up
Post #630264 1st May 2022 9:39am
Baltic Blue
Have you considered adapting them to become daylight running lights ?
I have seen them on cars on the road and they look well, but sorry can’t find a link to any at the moment.
I think I would adapt mine if they ever needed replacing because the fairy lights on my 2011 are pretty useless.
Post #630265 1st May 2022 9:59am
did someone mention my name.. Mr. Green
https://www.fullfatrr.com/forum/topic33047...t=led+fogs
and for Mike,
https://www.fullfatrr.com/forum/topic38570...t=led+fogs ... - .- -.
Post #630268 1st May 2022 10:32am
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Ive got a brand new genuine one for sale! 2014 vogue se
Post #630287 1st May 2022 2:26pm
