![]() | Home > Technical (L322) > Done something silly... |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
Going into London for dinner. Drove to my friends and noticed my auto lights hadn't come on so I thought I'd turn them on manually. Always think it's a good idea when the sun is low for extra visibility.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
im sure the dipped lights go out when the ignition is off just leaving the sides on...
So the dips do stay on then? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7985 ![]() ![]() ![]() |
I imagine yours will just be on side lights now.... 2011 Range Rover Vogue SE 4.4 TDV8
no, the dips go out .... ... - .- -.
There is on my 2011..... Depends how much attention you pay I guess, and if you think they turn off anyway...... 2011 Range Rover Vogue SE 4.4 TDV8
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Mjd, I know I have an older model, my lights I generally leave on auto, but iirc there is a bong if I leave the lights on, on non auto.
Yea, mine bongs if I turn the ignition off and the lights are on, but in the non auto mode.
Well it would seem that in an 07, if you leave the lights on manual it leave the sidelights on regardless!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Luckily you have a petrol model... My guess would be a Derv wouldn’t have started after 6hrs of side lamps |
Another reason the SC is better then Craig! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Another reason to fit led bulbs in the side lights. |
For sure |
