Home > Maintenance & Mods (L322) > Headlights 2012
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Headlights 2012
Hi to all.I noticed that when passing a gravel road the right hand side main beam is trembling.this is not happening with high beam.
I took off the back side plastic cover so to see if lamp base is ok and saw that the white plastic part (circled in photo)seems to be loose in comparison with the left headlight
Does anyone know what is the use of this plastic part and if loose or broken can cause such trembling
Best regards
Post #402548 30th Aug 2016 10:18am
i cant magnify the picture properly but could that be the lever for uk/europe beam setting... ... - .- -.
Post #402549 30th Aug 2016 10:23am
It's just the shutter that creates dipped beam wobbling a little when it's down , both high and dipped beam are provided by the HID lamp via an internal shutter that drops down and it will rattle a bit on rough roads . The high beam lamps are just halogens to flash and do a little bit of short range filling in , their parabola is not designed to throw light down the road .
And Stan is right of course, that's the lever for continental driving . 2008 MY Supercharged
Post #402555 30th Aug 2016 10:49am
AKIS
Many thanks for your replies but in attached video levering of headlight is done from another switch which,as u see video,is located on the right hand side and not from the white plastic one which is on the left side
Do i miss something?
Post #402576 30th Aug 2016 12:40pm
Your headlights are two models previous to those lights sir Thumbs Up 2008 MY Supercharged
Post #402578 30th Aug 2016 1:13pm
AKIS
Thanks axle confused because 2010 headlight also has the white plastic switch so thought would be the same. Embarassed
Post #402583 30th Aug 2016 1:39pm
AKIS
I am quite confused with head lights (the ones with black plastic insert)
Understood that trebling,some times, in main beam might caused by the shutter.However my headlights do not operate high and main beam fm same hid bulb.
The high beam is fm halogen bulb and normally lights when shift to high beam,is not only just for flashing ????
Any idea if headlights simply are not bi-xenon or there is another problem??????
Post #420186 30th Dec 2016 4:03pm
