![]() | Home > Maintenance & Mods (L322) > Whats in your boot ? |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
Long thick jump leads with Anderson connectors on - and a permanent Anderson connector on the battery - getting a decent connection to the battery is usually the trickiest part |
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
I have similar, heavy duty jump leads, a battery charger (not power pack as I would forget to charge it), a tow rope and straps for pulling daftys out the local hedges, trolley jack, some bungees, dog bowls and leads, gloves and towels, oh and some wheel nuts as one of my alloys has the smaller nuts |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Jump leads. Merc Sprinter bottle jack. 2 umbrellas. Gloves incase I need to change a wheel. 24" breaker bar and plastic coated socket for the wheel nuts. Heavy duty tow rope. C-TEK charger. Roll of spanners. 3 screwdrivers. Stanley knife. Roll of bodge tape. Pack of tie-wraps.
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2724
Yup, jump leads, don't have a merc sprinter jack, got a trolley jack in the garage + an AA card in my pocket. Also a portable potty. |
| Mikey32 Member Since: 10 Jun 2016 Location: Oxford Posts: 9
Alistair, Rosco, mzplcg, and Mr Tee
MIke the TD6 has a dedicated positive and negative terminal on the bulkhead in front of the battery compartment, not sure if the TDV8 has this? |
Explosive charge is just a fuse - so if you're bothered by it, just disconnect the negative lead completely before touching it.
Alistair.
Does the TDV8 not have a dedicated +/- seperate to the battery? Must have been an 'upgrade' for that model |
IIRC mine didn't - my '04 4.4 had one, but not my '07 TDV8 - changed with the folding key apparently - here
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
a portable potty!! now, i will be able to recognise a fellow forum member, if I see him sitting a few inches higher, in his range rover! -even more, if he has an 'angry' look on his face! |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Iirc you can retro fit the positive post.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
had to go and look,
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
When on the road I just carry the number to the breakdown service we get with our bank account, I ring them up and they send a little man to do all sorts of things so I don't have to get my hands dirty.... Always there in less than 30mins and if they can't fix it I get a free ride home....
| All times are GMT |
