![]() | Home > In Car Electronics (L322) > Another Rear Reversing Camera Issue. |
| HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169
there is a wiring book in the wiki section may be of some help
| Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570
Thanks HGV Driver, found some good links but still nothing |
| SteMY06HSE Member Since: 23 Jun 2016 Location: Doha Posts: 63
Hi Highroller,
Thanks for the wiring diagram SteMY06HSE. Managed to confirm that the feed & coax work ok after using another camera (12V security camera, would you believe).
Good to hear Highroller, was back in the UK last weekend so picked up a new camera from my local LR dealer. Less than half of what they cost here in the Middle East.
| STU TDV8 Member Since: 03 Apr 2016 Location: norfolk Posts: 65
Did you manage to find a camera that fitted the original wiring loom highroller ?.. |
Hi STU TDV8. Just waiting for the camera to turn up. Hopefully I can then add some photos & further info of how it's gone.
| TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50
Hi Highroller,
| n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754
There was some talk of a retro 2010 upgrade for 2006-2009 cars with some minor wiring changes and the camera housing needing a small alteration. I can't recall who did it but it was done.
Hi Folks, Hopefully I'll be able to update next week. Just received a small el-cheapo one from Hong Kong, just to confirm that all the connections worked & it showed a picture, which it did.
OK Folks. Camera all working & here's how I did it. This camera replace the original one & keeps it all looking original.
@Highroller
These are the dimensions of the original camera, as mentioned the replacement camera dimensions are very similar how this helps.
Thanks |
| All times are GMT |
