![]() | Home > General > L322 from 3.6 Tdi to 4.4 Tdi? |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Ideally they should move to SC and Turbo but that's not likely to happen with them getting every possible penny or of each car these days FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
I read it here, in this thread, but ive seen the same text in a press release somewhere....
To me that is describing the SDV6 be the tdv8(3.6) setup... I don't see mention of the 4.4 setup really FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
The 3.6 has 2 matching turbos with 1 turbo feeding each bank in the same manner as the 2.7 TDV6 as originally fitted to Jags. The 4.4 has a primary turbo on the right bank feeding both banks and a smaller secondary on the left bank contributing when operating, similar to the 3.0 TDV6 although the 3.0 TDV6's primary turbo is on the left bank and secondary on the right bank. |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850
Have owned both the 3.6 and 4.4.
Greame do you have any backup info for this at all as I'd be interested in seeing how it's all plumbed in |
These diagrams from the D4 workshop manual are for the 3.0 TDV6 so the primary and secondary turbos are on the wrong sides for the 4.4 TDV8 and the 3.0 has a single air-box whereas the 4.4 has 2, but otherwise show the flow. The first diagram isn't quite correct because the turbine shut-off valve (2) prevents exhaust flow through the secondary when closed yet the diagram shows that exhaust gas still flows, but perhaps a small flow still occurs.
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Whale oil beef hooked. I've learned so much in the last set of posts. What a fine and knowledgeable bunch of chaps you are |
| JohnJ Member Since: 22 Apr 2016 Location: Varese Posts: 41
thanks so much for all the comments... I am very tempted to the upgrade to 4.4 since 405 is out of budget and honestly, too flashy for my taste... but my 3.6 interiors do tend to show the passing of time too much for my taste...
I've not seen much regarding turbo issues on the 4.4. The 3.6 yes, but not the 4.4.... yet anyway....
| All times are GMT |
