![]() | Home > In Car Electronics (L322) > Approach Lights Inop. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8704 ![]() ![]() ![]() |
You know they only work when the car has been locked and you unlock it..??
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Highroller, Please let us know if you get to the bottom of the problem. I have the same issue and sadly gave up it. One day I will wire them into the puddle lamps. 2007 TDV8 VSE
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
As I've tried all of the known quick fixes. Wiring them to the puddle lights may well be my next move. |
FIXED!!!!.
When you say you removed the glovebox is that literally? Where is the relay location, I only see fuses in my glovebox fusebox. 2007 TDV8 VSE
Wayneg, The relays are behind the fuses & yes just had the glove box sat in the foot well. It is a bit of a work up but it is do able.
orangelemon Member Since: 17 Jan 2018 Location: Essex Posts: 1 ![]() ![]() ![]() |
hi having the same problem - been at it for hours now, even with the standard bulbs I now get a single flash only - Did you replace the relay or simply take it out and put it back in? Have tried disconnecting the battery (twice) so annoying this problem and any help appreciated |
Hi Orangelemon & welcome to the Forum. I only removed the relay, cleaned the connections & replaced it. If you are using the correct 6w bulbs, then hopefully this will reset them.
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
I'm confused what are the approach lights? |
These are small downward pointing lights in the door mirrors, they supposedly come on when you unlock the car. 2007 TDV8 VSE
Thanks for that. I always thought they were called puddle lights. Cheers.... |
Puddle lights are at the bottom edge of the doors 2007 TDV8 VSE
OK Thanks for that |
Just to add to the confusion regarding lights. Today I have lights on all the interior door pockets & release handles. |
