![]() | Home > Technical (L322) > Overlanding L322 build, Mechanical |
| cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 |
I don't know who told you the BMWs are better but I would steer you toward a 4.2 Jaguar 07+ with rear locker and e locking center.
| Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227
Re Parts, you are correct. For some reason they CAN be extremely high in Oz.
| royalgoldfish Member Since: 04 Sep 2016 Location: Melbourne Posts: 30
I was reading on the forums that the BMW's in the 4.4 managed higher km's and sound be worked on easier eg. timing chains and parts were more readily available as the engine is found in the 5, 6 and 7 series plus the X5 Don't let school get in the way of your education |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
I do a bit of touring and my main concern was tyres after a couple of horror trips in the past with multiple puncture in remote areas. On the earlier cars you can fit 18 inch rims which opens up the choice of rubber. I run 265 60 18 as they are std on Landcruisers, Pajero`s, Rangers etc and therefore very available, just looked in my local small adds and there is a good used set of 4x AT22`s for $100. I have a 2003 TD6 and the Range on a tank can easily be 1000klms, 2007 TDV8 VSE
How many km's do you have on your vehicle mate? I was told getting up in the kms with the TD6 spells trouble for the gearbox and turbos? Don't let school get in the way of your education |
Mine has 212000klms on it. You need to be very careful of the gearbox with a 200000k lifespan but the engine is a peach and pretty bullet proof. I sat and watched the market for a year until I spotted mine with easy diy issues but just had a dealer gearbox, torque converter and cooler fitted. The guy said it had a turbo swap a few years back but no bill to prove. He never even mentioned all 4 discs and pads were just replaced, still looking shiny new. I am ready to do the turbo if it goes south, A core is less than A$150 to DIY.
waned thats really good to hear mate, I'm doing the waiting game as well, the V8 apparently has a 250k lifespan or so as well so i figure buying at 120k gives me heaps of leeway before it needs to be addressed. You sounds like a diy man a well, is there much you can't do that pops up? eg. electronics or special tools to remove stuff? Don't let school get in the way of your education |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
I'm not sure about the BMW petrols being better than the Jags, but they'll have more miles because they've been around more. I'd recommend the following: good protection (underbody, bumpers), fault code reader, good spares supply, strong 18" tyres. Enjoy! |
I have a good toolkit and home garage and so far no special tools needed. Things seem to come apart and go back together well so build quality is good. I have an icarsoft code reader / clearer which is the minimum you would need if leaving the tarmac. I would highly recommend one if you cant stretch to the high end diagnostics. Cost for parts is very cheap if you are careful using ebay and the like. Double check with BMW parts as many are the same and cheaper for earlier cars. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
Thanks very much wayne, this is all the info i need to make my decision, Ill have to play the waiting game now to find the "right" one. Cheers. Don't let school get in the way of your education |
| All times are GMT |
