Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height
Page 4 of 5 <12345>
tassietd6
Australia
Fixed
Hey, guys! The "Air suspension inactive" message reappeared and once again she was stuck in off-road height. I had to go down to Hobart (I live in NW Tasmania) so I booked her in with an independent for a check. My mate owns an independent VW workshop and I always stay at his place when in Hobart. When I arrived at his workshop he pulled out the diagnostic tool that he uses ($11,000) and lo and behold...it had a chip for the L322! So we plugged it in and read the codes...the only one that came up was the inactive suspension variety. He explored further and found that his tool could recalibrate the suspension settings. As it was, the height from the wheel rims to the wheel arches was 480mm which is at the high end, so we reset it to 460mm. As soon as this was done the suspension behaved as normal and would rise and fall according to the switch (previously the switch lad no LEDS and produced no result). The next day I went to the independent RR workshop and the owner confirmed that we'd done the right thing. So that was 3 weeks ago and I've hesitated to write anything on this thread just in case the dreaded "bong" resurfaced, but I'm happy to say that the suspension is working fine. My advice to all of you L322 owners is if you have this problem emerge, get the suspension recalibrated before you panic and spend a lot of money unnecessarily. In the case of mine, I still have a nagging feeling that one of the sensors is misbehaving but I'm probably being paranoid. Oh... on the trip to Hobart and back + running around there I did 1000km and had a diesel consumption of 8.4L/100km. OUTSTANDING!
Post #311695 9th Feb 2015 2:00am
RR2008HSE
Nice piece of advice. Much thanks! Thumbs Up
Post #311862 9th Feb 2015 10:56pm
jonbaobao
2007 Range Rover Supercharged 4.2 SC V8 Java Black
Dealer wanted to charge me 8000usd to get a new compressor...... Sad LR don't try to manage there dealers better. It made me want to move away from the brand.
Post #403430 5th Sep 2016 3:21pm
mjdronfield
Well, stuck in extended mode. Local garage said code was “failure to vent vessel” or similar.....
New compressor is about £800 fitted. Rang dealer who said you can’t buy filter plug separate anymore so I’m trying to clean the old one myself.....
I assume this is it?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #457370 15th Nov 2017 2:20pm
thats the one...drill a small hole in it to let it breathe.. Thumbs Up ... - .- -.
Post #457386 15th Nov 2017 3:30pm
bishbosh10
Yep - what Stan said - a small hole in the end will fix your woes. Smile Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #457437 15th Nov 2017 9:52pm
mjdronfield
Sorted I think
Many thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #457444 15th Nov 2017 10:19pm
dazza1983
Did this fix yours buddy?
Post #506336 25th Feb 2019 5:10pm
mjdronfield
It certainly did.
No issues going up or down since.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #506338 25th Feb 2019 5:33pm
dazza1983
Thanks bud.
Post #506400 25th Feb 2019 10:51pm
Main dealers may not sell the filters separately but if you search on eBay for "sintered bronze filters" you may well find what you need for a few pounds. Thumbs Up
Post #506420 26th Feb 2019 7:56am
RJ333
United States 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I had the venting problem too. I did not drill the hole in my bronze filter but I just cleaned it. But after cleaning it twice I wanted a better solution. So, you need to change out the dryer dessicant on this compressor when the filter starts clogging, because it is the dessicant that is turning to dust and clogging everything.
I found a kit to do this for about $40 shipped to the US From England. The website was 4x4 air seals.
So far so good.
Just another tip. This also might be helpful if your exhaust valve is clogging too.
2011 supercharged full size range rover
Post #559404 28th Jun 2020 5:33pm
mjdronfield
Nice one. Have you got a link for the kit?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #559407 28th Jun 2020 5:48pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Has anyone changed the filters or driers inside the compressor?
Mine is hitachi comp. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #563559 4th Aug 2020 2:10pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Try here
http://4x4airseals.com/product-category/landrover/rangeroverl322 2011 TDV8 Vogue SE
Post #563560 4th Aug 2020 2:28pm
Page 4 of 5 <12345>
