Home > Technical (L322) > ZF 5HP24 hissing noise
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
Just, remembered that when I was reversing rangie to garage I noticed a hissing noise coming from transmission when reverse gear was engaged. Otherwise it seemed to work ok. Still don't know if there is more gears than 1 and R. Could not compare with 730d autobox as M57 is so loud. Is this noise normal? Surprised -08 3.6 Vogue
-87 951
Post #403402 5th Sep 2016 12:16pm
Mine makes the same noises both forward and reverse and it doesn't hiss at all, usually hissing is a leaking airbag or pipe... Thumbs Up Pete
-Click here for Thread-
Post #403488 5th Sep 2016 6:48pm
kimlahti
I guess it is not normal then. Very Happy Sound is like overpressure valve letting fluid out. I'll try to take some video when RR is back on four wheels. And from PRND it only happened on R. C-clutch leaking perhaps... Maybe it will show up when I can take it to first test drive. Very Happy -08 3.6 Vogue
-87 951
Post #403551 5th Sep 2016 10:31pm
