![]() | Home > Maintenance & Mods (L322) > Front Diff/prop failure. |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1432
LRCR is 0870 5000 500. Good luck. Only Range Rovers since 1988 |
| Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201
Thanks mate |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
If you end up paying, use second hand bits off eBay... much much cheaper and if they are the modified ones (and I haven't seen an unmodified one yet) then they will be fine.... |
Do you think I need to worry about the mileage of the donor part or is it the coupling that is the only part that generally fails ? 2003 Vogue 4.4 V8 Java Black |
Get the lowest miles you can but don't worry too much, most places give a warranty and a mechanic should be able to check it before it's fitted... |
Called them, they searched my VIN and told me there's no outstanding recalls shown for my vehicle ? They didn't seem to know anything about a front diff recall at all (I thought it was a big issue??) . They asked me for a recall no. Or a service action request no. ?? I don't have either ???
Also - as a credit to this forum - the JLR customer service asked for my VIN , once I gave it she types away --
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1045
You need to quote the Q041 Service Action from June 2008. Land Rover were careful to describe it as a “Loyalty Assurance Programme” and not a recall.
I think the recall was in 2008, but there were failures before that which would have been repaired under warranty or at the owner's expense - yours was presumably a warranty job if the car was only a year old. The problem seemed to have been caused by misalignment and I believe the recall repairs incorporated a joint to make that less of an issue, perhaps in 2004 there was no additional joint and so your car remained vulnerable, even if it did last 12 years.
| RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 226
Were there any symptoms? I had a whining diff on my 2005 S/C for some time, then replaced it with a genuine new one which was much better but then it started whining. It was then replaced with another new one which now whines so loud, I can hardly hear fthe wireless. All within in a two year time frame. I changed the oil in the current diff yesterday. It was like Bisto and the drain plug had a thick coating of a silvery grey gunge.
| Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409
LR (Guy Salmon, Knutsford) replaced the front diff in my 2004 car in January 2012.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
Mine was done in Dec 2011 by the local dealer and I was told that it wouldn't be long before they wouldn't get any more authorised....on my TD6, obviously....
| All times are GMT |
