![]() | Home > General (L405) > ARC valve block advice |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Well, if you're worried and the car is still under warranty, I'd recommend fixing it. If it's your own $/£, and it won't cause damage, I'd wait until there's a problem unless you are expecting a long trip away from easy servicing. |
Jon S Member Since: 10 Aug 2016 Location: Exeter Posts: 32 ![]() ![]() |
thanks- it's not under warranty anymore. that's my problem. I Just wanted to get a feel for whether it's something the majority have had done or if it's just a handful of unlucky ones. |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Hi You should ask your local Land Rover Dealer to check on the JLR system if the valve block has already been replaced under warranty or service bulletin. This will let you know if you need to worry about it. It is a big job and would cost heaps.
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 721 ![]() ![]() |
It's not a case of them going wrong, the first couple of model years were wrong out of the box. The design of the ARC valve block was updated to include dampers. If you can't hear and feel knocking from the suspension over bumps then your car must have had the block changed at some point. |
vanquishspirit Member Since: 10 Feb 2012 Location: United Kingdom Posts: 133 ![]() ![]() |
Do you have any more information on the ARC valve block please? I am struggling to get LR to do this but the car knocks like there are no rubber bushes in the suspension. Why it has to be such a challenge with LR. I mean why not do the job properly? Anyway, can you tell me what was incorrect with the original valve blocks please? 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
bra10j Member Since: 09 Aug 2016 Location: Aberdeen Posts: 34 ![]() ![]() ![]() |
My car still has a knocking from the front end but it's an SDV6 so I'm wondering if it even has the same valve block assembly as the TDV8. Can anyone clarify? I've had it back to the dealership many times for front end knocking and both uprights have been replaced as well as something about the active roll bars but never any mention of this ARC block. If someone could advise that would be much appreciated as it may help them identify the issue. Current Fleet;
The V6 does not have ARC so if you have a knocking sound it's due to something different. |
Thanks. That's what I suspected so thank you for confirming. The hunt continues! Current Fleet;
