Home > Maintenance & Mods (L322) > Rear light cluster water ingress
GaryPFC
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
I noticed that water ingress, must have been when it was jet washed, I removed & it appears intact so must have been forced in at a seam.
I drilled a small 4mm hole to drain the water (1/2 egg cup) but can get rid of the residual so I've have plugged the hole.
I hear a new unit is expensive ~£600, so can anybody advise how to dry them out?
Thanks Thumbs Up
Post #403976 8th Sep 2016 6:52am
Remove light, take all the bulbs etc out then in the airing cupboard until it's dry, don't take it out the airing cupboard if it's real cold outside or condensation will fog it up again... Thumbs Up Pete
Post #403989 8th Sep 2016 8:25am
i'd leave the hole you've drilled un-pluged so the light unit can 'breathe'. ... - .- -.
Post #403990 8th Sep 2016 8:27am
Big Boy R44ROV
I'm with Pete on this. I did the same. I also used superglue round the edges of the light unit to re stick it, and then when that had dried, used clear silicon over the top very thinly to ensure no more water ingress. Totally invisible repair. Its been jet washed loads since and not a drop inside the light.
Don't use the tumble dryer to dry them though ! Thumbs Up Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #404007 8th Sep 2016 10:00am
Duracell777
Same problem with mine. 3mm hole drilled in the bottom of each and not had a problem since. ( took couple of days to clear)
As Stan said, leave hole unplugged.
Post #404124 9th Sep 2016 12:33am
GaryPFC
Thanks guys seems sensible to leave it inpluged, I will also leave in a warm spot overnight to dry out once opened. Will report result Thumbs Up
Post #404248 9th Sep 2016 8:30pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
If you can find a warm spot in Aberdeen you dont have to worry about lights Rolling with laughter
Post #404251 9th Sep 2016 9:03pm
