|  | Home > Maintenance & Mods (L322) > Rear hub |
| Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36    |
 I'm trying to change the dust cover for rear brakes which requires removing the rear hub. I've undone the centre nut and have tried a puller on the hub but it's not budging and I don't want to put too much pressure on hub. Is there something else I should be doing in order to remove hub or should it just pull off once centre nut is removed.
|  8th Sep 2016 3:19pm |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277      | As far as I can see from RAVE it needs a puller to remove the hub.
|  8th Sep 2016 3:39pm |
| Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36    | I have taken the disc and all the hand brake bits off so all I'm left with is the hub, looks like it should just slide of the spline but it's not happening If you like it, who cares what other people think | ||
|  8th Sep 2016 3:41pm |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277      | See above.  I was typing at same time as you. John
|  8th Sep 2016 3:47pm |
| Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36    | Thanks for that weegie, so there is nothing else holding it on? I guess I need to up the effort on the puller. If you like it, who cares what other people think | ||
|  8th Sep 2016 3:53pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | You can't pull the drive flange off with the hub still on the car, you need to remove the drive shaft which is an exact fit in the flange and very tight, you then remove the whole hub and get a massive press to press the drive flange from the hub, this will wreck the bearing if you manage to do it. After a new bearing and more swearing It's then a pain getting the driveshaft back in as you have nothing to hammer...
|  8th Sep 2016 9:02pm |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277      | This thread:
|  8th Sep 2016 9:10pm |
| Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36    | Thanks guys, no wonder I couldn't get the effin thing off. Time to get the dremel out and get cutting. If you like it, who cares what other people think | ||
|  9th Sep 2016 6:51pm |
| Posting Rules
