Home > Technical (L322) > Air suspension woes
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Air suspension woes
Please someone help me understand my issue and also break the bank Sad
Basically, the front air suspension keeps going down, and when it pumps up to normal ride height, I get a whoosh of air come down between the front right airbag, as in where the top overlays the bottom.
If I leave it running and read the values, the height constantly changes... but the reservoir pressure stays the same so am I right in thinking it's getting to a level and not leaking anymore?
I take it I need a new front right air bag Sad
Also, why is the ride height sometimes - and other times not at the same level?
Post #404152 9th Sep 2016 11:14am
put it in off road and spray soapy water on it...this should confirm your suspicions.. ... - .- -.
Post #404158 9th Sep 2016 12:30pm
Stacker
Cheers Stan, although I can't seem to get it there haha I will have a look later it might have been because I was in a rush!!
Post #404159 9th Sep 2016 12:35pm
Those ride height figures are just a datum point for the EAS to know where each wheel is, they don't mean anything on their own.... Pete
Post #404200 9th Sep 2016 6:02pm
Stacker
That clears that up!
Won't raise to off-road mode though, is it still ok to drive?
It only drops majorly over time, I expect at normal height it should be ok until I can replace it?!
Post #404206 9th Sep 2016 6:28pm
Puts a lot of strain on the compressor, but it'll be OK for a short while.... Thumbs Up Pete
Post #404215 9th Sep 2016 7:03pm
Weegie
You can drive it but if it is going down you are overworking the compressor which will eventually give up. Then you have aditional cost replacing it.
Sooner you change the strut the better. Also advised to do both as the other one may not be far behind. John
GAP iiD BT-Sold
Post #404218 9th Sep 2016 7:07pm
Weegie
Pete beat me to it! Very Happy John
GAP iiD BT-Sold
Post #404221 9th Sep 2016 7:07pm
Stacker
I will hopefully be able to replace next week.
Got to drive to Birmingham on Monday and back, other than that I don't really use the car that often.
Just literally can't afford it right now, everything is going wrong with this car. More depressing thing is I have a 4.6 p38 sat at my grand parents which is mint!!
Post #404285 10th Sep 2016 8:28am
Sandyt
I had a leak on mine and ran it cost me 600 quid for a new compressor Shocked
Post #404362 10th Sep 2016 10:50pm
holidaychicken
Make sure you take your diagnostics with you so when your compressor overheats and cuts out you can reset it and do a proper job of ruining it...
I wouldn't be driving more than a few miles like that and if it is the front struts then Delphi from island 4x4 were always good and the Dunlop I put on mine weren't much cheaper and they knock for some reason.
Post #404366 11th Sep 2016 5:23am
markcartlidge
My N/S Front went a few months back and chaged it. £264 from Paddock for Delphi. £15 more than Island but happy to paymore for a more responsive supplier.
Last week my O/S front went. It would leak at standard hieght, right where the bag had perished on the bend, so I used my IID to raise it 20mm until I could get the new one and replace it. Both strutts were factory original.
Just hoping the rears dont go anytime soon.
Post #404368 11th Sep 2016 8:12am
holidaychicken
Didn't know you could get hold of these now
http://www.island-4x4.co.uk/spring-strut-f...34328.html
http://www.island-4x4.co.uk/spring-strut-f...30687.html
Post #404370 11th Sep 2016 8:38am
Weegie
For the cost difference, personally, I don't think it is worth just changing the bags. The struts are the same age and probably will be worn as well. Also you still have to strip the units out to make the repair. John
GAP iiD BT-Sold
Post #404371 11th Sep 2016 8:45am
holidaychicken
I agree, I was just a bit surprised to see them there, i know there was a company offering their own brand ones but these appear to be landrover part numbers by Delphi.
Post #404378 11th Sep 2016 10:43am
