![]() | Home > Maintenance & Mods (L405) > Towing |
From what you describe it could be a number of things. I would be checking stuff you mention like height of the towball, weight on the towball both laden and unladen. I might also be tempted to get the car 4 wheel aligned and check all the suspension bushes for wear.
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I have the electrically deployable tow hitch and use it regularly to tow an Ifor Williams horse trailer and have never experienced any problems. Maybe checking your wheel alignment is a good place to start. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8044 ![]() ![]() ![]() |
It certainly sounds strange - I didn't notice any difference switching over.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2618 ![]() ![]() |
As above, hitch height sounds most likely. |
peekay Member Since: 07 Nov 2011 Location: London Posts: 91 ![]() ![]() |
Apologies, updated profile now but yes it is an L405 on 21" wheels. No wear on tow vehicle, only 10 days old!!
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
I tow a very large caravan and it's very heavy when full! I have the plug in tow bar which does rattle a bit, the Range Rover tows very well the 4.4 has masses of power, good to see how you get on 2010 defender utility
Just because the car is new you shouldn't assume the wheels are all aligned properly. My brother's X5 went through its first set of tyres in 15k miles due to the fact it came misaligned from new. |
vanquishspirit Member Since: 10 Feb 2012 Location: United Kingdom Posts: 131 ![]() ![]() |
I found that pulling an empty tri axle enclosed car transporter was an awful experience. Like you the car was bashed around and rattled like hell. As soon as I had weight in the trailer it was fine. I put it down to the indespension units on the trailer which are specified for weight and when empty really have no compliance. As the trailer bounces it transmits that to the tow car. Perhaps its all to do with the alloy construction which makes the L405 more susceptible to it. 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
peekay, any resolution to your problems?
Afraid not, Still as it always was. Have had everything checked and all
