![]() | Home > Maintenance & Mods (L322) > Front Lower arm suspension bush fails rapidly. Ideas please. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8700 ![]() ![]() ![]() |
I would think the only "normal" thing that would accelerate wear is continued dry steering...
belldarr Member Since: 14 Jun 2014 Location: Bucks Posts: 149 ![]() ![]() ![]() |
Hi - I did read that when fitting these whoever does it needs to just loosely fit the bolts while the car is on the axle stands - then when the weight of the car is back on the wheels you can tighten the bolts up to spec - this stops the bushes "twisting" under load - this leads to premature wear, could this be the problem?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
^this is true, and I have had a set go because of it. 4 post ramp is a must!
It says in the post that the first set may not have been tightened like that but the second and third set were....... Pete
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 ![]() ![]() ![]() |
Can't see it being a steering alignment issue as the tyres that were on it when she arrived were merely very worn. Far too worn but evenly so.
Dry steering means turning the wheels when the car is stationary, with power steering this puts a lot of stress on the suspension arms, you should be moving, even very slowly before you turn the wheel.... |
Id maybe go for a long drive with her and see what she's like. Maybe there is a certain bad road thats hammering the bush in a weird way but to me it sounds like they may need fitting as above and a proper 4wheel laser alignment done as well. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
It could be a country road, the road I used to drive down to site had terrible potholes on the N/S. Used to eat ball joints on the transit and Renault vans. There is nothing that can't be fixed with a hammer😜😜
Bumping this thread as she has gone through two more sets of lower arms and the knock is still there.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
May not be related but do you have Dunlop struts ? |
Far as I know they are still original ones on there. Car has done 89,000 (ish) miles and I'd have probably have heard if they had been changed.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I have a knock that is coming from the OSF on mine and it is definitely not bushes but probably the strut.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
