![]() | Home > Technical (L322) > Rough idle on 2002 Vogue 4.4 V8 with lpg conversion |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
When our FFRR starts it runs rough, i'm guessing it is missing because there is a definitive smell of fuel out of the exhaust - on petrol & gas.
*lpg not log |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
title edited for you |
Cheers Stan |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8793 ![]() ![]() ![]() |
Is that just starting from cold or does it do it when hot..??? Pete
So if we've been driving and turn the engine off then back on again it'll run rough again so yes it does it when hot too |
The engine ECU richens the mixture on cold start for a while, similar to the old choke, mine smells of fuel if you stand at the back as well when this is happening..
The radiator coolant temp looks low.
After driving a short distance and issue is not occurring
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Maybe a leak in the vapouriser which seals up when hot? |
It does it on petrol as well |
If it was a missfire you would have a MIL light on...
When I turn it off then on again it is lumpy straight away.
Check the STFT (short term fuel trims) with it running and see how far out they are, should be within + or - 10%
I'm not sure what the short fuel trims will come under? I can't find them
