![]() | Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2236 ![]() ![]() ![]() |
Doh didn't realise that - hopefully I can do it through the engine bay not have to take apart AGAIN! |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
Nice to see that there is progress for using alternative high pressure pump.
Good day.Any chance for a reply please so start replacement of pump |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
for the headlight washer pump wiring, on the old LH headlight washer connector you connect the black/yellow wire (pin 4) with the brown/black wire (pin 1) i just soldered a wire across them which activates the pump when the headlights are on.
So i have to actually bridge pin 1 and 4 of the old lh headlight washer connector.
Obonano Member Since: 22 Feb 2017 Location: Houston Posts: 2 ![]() ![]() |
Good afternoon guys i am planning on doing the conversion to my 2008 but got a question on the bumper washers can I reuse my pump and tank or will it have to be modified and What other things will need to be modified or that could be reused in the 2008 model thanks |
Hi
Hi Matt
Bump |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
looking at the 2010 lights over and over again, they look very similar to the 2006 version, out of interest did you offer up the lights to the 2006 grille before doing the rest of the converson ? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6800 ![]() ![]() ![]() |
^ despite you thinking they look the same, which I disagree with, the grillles and headlights for each respective model don't fit each other. Got - 2017 SDV8 Autobiography in Loire Blue
You can see they are turned in when you looke at them and the units are flush to the body work lines. I can see silver paint on the outside side of each projector one a lot more than the other... |
Dan a few questions
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 54 ![]() ![]() |
sorry to be a pain is there anyway to get the guide with all the pictures again I cant see them and if possible would help me plan my install? |
