Home > Technical (L322) > Folding mirrors - sort of
steadyaway
Today while parking up I pressed the mirror fold button. Only the drivers side folded in. I lowered the passenger window an got SWMBO to gently pull on the mirror while I tried to fold it again. This time it folded. When I unfolded it, it did it by its self. So I tried to fold it in again and once again it failed but worked with a little persuasion. I would assume that the motor is ok but there is obviously a problem somewhere. Has anyone had a similar issue and can point me in the right direction please?
Post #374616 27th Feb 2016 11:48pm
Sandyt
I had something similar a few months ago there is a reset by double tapping the button that operates them there is a post on here about it but try the double tap i.e. tap the button twice in quick succession hope this helps
Post #374635 28th Feb 2016 8:29am
steadyaway
I'll give that a go, nothing to loose. Cheers.
Post #374652 28th Feb 2016 11:36am
kbald
I had exactly the same and a double tap worked for me too! There was mention of removing a fuse if it didn't work to reset them aswell. Worth doing a search as there was a fair bit of info about it they go out of sync for some reason!
Post #374658 28th Feb 2016 12:39pm
steadyaway
Post #374660 28th Feb 2016 12:49pm
Or the microswitch has packed up/got damaged in some way. .
Post #374661 28th Feb 2016 12:50pm
steadyaway
The nearside mirror now folds.........by its self without even pressing the button! When I have my towing mirrors fitted, the air pressure folds the mirror in slightly. I suspect the motor or the gearing. I have watched the YouTube video by powerfuluk explaining how to remove the mirror but I think they did it on a HSE. As mine is the Vogue the trim panel on the inside of the mirror is different as mine has a speaker there. Can anyone tell me if removal is similar or what else I meet to do.
Thanks.
Post #404764 14th Sep 2016 8:22pm
steadyaway
The nearside mirror now folds.........by its self without even pressing the button! When I have my towing mirrors fitted, the air pressure folds the mirror in slightly. I suspect the motor or the gearing. I have watched the YouTube video by powerfuluk explaining how to remove the mirror but I think they did it on a HSE. As mine is the Vogue the trim panel on the inside of the mirror is different as mine has a speaker there. Can anyone tell me if removal is similar or what else I need to do.
Thanks.
Post #404765 14th Sep 2016 8:23pm
steadyaway
Apologies for the double post. I tried to edit the first. Banging Head
Post #404767 14th Sep 2016 8:31pm
tiddles1991
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
Interesting to hear about the double tap, I shall be trying that on mine!
Post #405293 18th Sep 2016 9:09pm
