Home > Technical (L322) > 4.2s/c How much smoke?
RuthlessGK
United Kingdom 2005 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
Hey Up Everyone,
My 4.2 s/c seems to put out a lot of smoke when starting the car either first thing in the morning or after letting it stand for quite a few hours but after this while driving etc it doesn't smoke at all.
Coolant is at the same level it has always been and oil level is the same although it is slightly overfilled by approx 2cm on the dipstick.
Can anyone please let me know what it could be.
Zaff Current Cars -
FFRR L322 4.2 Supercharged 'Bonatti Grey'
Mercedes C270cdi
Post #404871 15th Sep 2016 5:45pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I hope you mean overfilled on the dipstick by 2mm. If it really is 2cms I'd be inclined to get some out.
Mine spits a little blue smoke if it's been standing for months, which does happen on occasions. Left for a few days I get no smoke at all. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #404872 15th Sep 2016 5:49pm
RuthlessGK
I need to drain some out I know. It's white smoke only. No blue. Current Cars -
Mercedes C270cdi
Post #404873 15th Sep 2016 5:50pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Sure it's not steam? Mine puts out a surprising amount of steam for a surprising length of time from a cold start on a cold morning. This time of year no steam or smoke at all.
Post #404876 15th Sep 2016 6:03pm
RuthlessGK
See that's my issue. It's been roasting and it still does it on startup. Looks like a bloody steam train at first but then after 5-10secs it's gone
Zaff Current Cars -
Mercedes C270cdi
Post #404884 15th Sep 2016 6:42pm
kezbo1981
Can you get a photo or video of it?
Post #404905 15th Sep 2016 8:06pm
RuthlessGK
I will get a video over the weekend but if anyone has any ideas before then let me know.
Zaff Current Cars -
Mercedes C270cdi
Post #404925 15th Sep 2016 10:21pm
fisha
I'd drain out some oil. 2cm above is too much above really to be honest. Easiest method I would use is to loosen the oil filter till it starts to spill out. It should run off the filter and be reasonably easy to collect in a pan. Collect about 1 litre out and retoghten the filter. that should bring you back to within the min max levels. If you take too much out, then it's easy to add more back in. V8 or else ...
Post #405324 19th Sep 2016 4:36am
I wouldn’t think the car would still be running if the dipstick was 20mm above the max mark Fisha... Probably meant as 2mm Thumbs Up
Post #405330 19th Sep 2016 8:42am
RuthlessGK
Apologies. Looked at the dipstick again. It is overfilled but between 5-10mm which is still alot I know. I will try and extract some via the filter.
The startup does have a blue colour to it but then never again when driving. Here is a quick video as my Missus was indoor holding the little one and a camera lol.
<iframe></iframe>
Cheerz
Zaff Current Cars -
Mercedes C270cdi
Post #405358 19th Sep 2016 12:45pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Mine is an 05, done 93000 miles and no smoke at all. I would look at the oil level first! Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #405390 19th Sep 2016 2:52pm
kezbo1981
Hard so say from that video, but it does look a little oily to me. Get the oil level down to the proper amount and that may solve the problem. P.s. I wouldn't necessarily drain via the filter as it could be messy given where it is on the SC. Maybe better using the drain plug.
Post #405455 19th Sep 2016 8:06pm
fisha
The drain plug is messier. It doesn't really drain when you loosen it. Its an all or nothing affair with that plug.
I changed the oil a couple of days ago and found that although when loosening the oil filter, it spilled over the pipes and tubes under it, the oil just fell downwards into the pan and any mess was early wiped away with a rag after. V8 or else ...
Post #405528 20th Sep 2016 11:50am
RuthlessGK
Thanks for all the responses and advice. Anyone got a diagram of where the oil filter is located? or just generally where it is. Im at work at the moment so can tstick my head under the bonnet to look.
Zaff Current Cars -
Mercedes C270cdi
Post #405544 20th Sep 2016 1:25pm
kezbo1981
Accessed from underneath, front of the engine. Under tray off job. Personally I would use the drain plug, but you can decide.
Post #405616 20th Sep 2016 7:41pm
